What does 'Analyzes Geometry for errors' say?chennes wrote: ↑Thu Apr 22, 2021 12:43 pmThe way I tested it was to remove the final boolean operation from the tree, and try to do it "by hand" in FreeCAD. I get the same results. Something about some of those objects is rendering them "uncuttable".keithsloan52 wrote: ↑Thu Apr 22, 2021 7:27 am My thoughts are on the lines that there is a bug in the importer that is causing the Placement of the plane to be wrong i.e. at Base (0,0,0) rather than a correct value and hence not cutting correctly.
Could be a case of saving as Brep file and checking with OSS tool (Sorry forget name)
