Opening an .scad file its parts are put to the wrong coordinates on screen
I wanted to use TechDraw to create some 2D black and white images, so I opened the the file in FreeCAD. It is an axial flux type of gear and rotor from the gear is placed at the wrong place. I could render the file in OpenSCAD without any warning using F6 and it reported as Simple:Yes.
However TechDraw put everything at the right place. See attached files.
The first few lines in the Report View:
23:44:05 ImportCSG Version 0.6a
23:44:05 Start Lex
23:44:05 End Lex
23:44:05 Load Parser
23:44:05 WARNING: Token 'DOT' defined, but not used
23:44:05 WARNING: Token 'WORD' defined, but not used
23:44:05 WARNING: There are 2 unused tokens
23:44:05 Parser Loaded
23:44:05 Start Parser
23:44:05 Vector
I use the latest supported release of both programs. I use a "trashcan" type MacPro 2013 with 48GB memory with Catalina /MacOS 10.15.7/ on it. Any good hint what is going on with the Import and how to fix the wrong presentation?
Thanks ahead,
Infocean
23:44:05 Start Lex
23:44:05 End Lex
23:44:05 Vector
Thanks ahead,
Infocean
- As it is in OpenSCAD
- Screen Shot 2021-04-03 at 9.21.46 PM.png (110.63 KiB) Viewed 1582 times
- As TechDraw see it.
- Screen Shot 2021-04-03 at 9.18.10 PM.png (113.61 KiB) Viewed 1582 times
- As FreeCAD sees it.
- Screen Shot 2021-04-03 at 9.17.53 PM.png (137.09 KiB) Viewed 1582 times
Re: Opening an .scad file its parts are put to the wrong coordinates on screen
Without any file and knowing your version of FreeCAD, anything would be blind guess.
Hi OpenBrain,
OpenSCAD ver 2021 01. FreeCAD 0.19.
I attach the file, so you can see.
Thanks ahead,
Infocean
Thanks ahead,
Infocean
Well, I did not attach it, looks like.
- Turbine first gen only.scad
- (9.07 KiB) Downloaded 22 times
Chris Hennes @chennes Has been doing some work on OpenSCAD tidying things up, but I fear he may have introduced a bug or two.
If I load the file up with my Alternate Importer https://github.com/KeithSloan/OpenSCAD_Alt_Import
I get Which is a lot closer although one flange seems to be missing for some reason from your attempts.
If I load the same file into OpenSCAD I get which to me looks the same as the version using the Alternate Importer.
Apart for the handling of hull & minkowski requests my Alternate Importer uses the old importer code, so another option might be to try an old FreeCAD release at least for the import.
I am sure if we alert Chris he should be able to resolve fairly quickly.
Just noticed that you are using OpenSCAD 2021.01
So updated my version and your file still looks like i.e. the same as Alternative Importer and different from your original post.
Thanks, Keith, I should be able to look at this later today.
Here's what I'm seeing on my machine, which I believe is correct:
OS: Windows 10 Version 2009
Version: 0.20.24694 +1 (Git)
Build type: Debug
Branch: pr/4730
Hash: 31ff2ff137bb2d35245fe8db5c0564284527d812
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
@infocean, can you please post your version info?
I'm on:
Build type: Debug
Branch: pr/4730
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
I should also add that, although the work I have been doing is destined for 0.20, since it's Python, users of 0.19 can download the two files involved and just replace their versions.
https://raw.githubusercontent.com/FreeC ... portCSG.py
https://raw.githubusercontent.com/FreeC ... eatures.py
By the way @infocean Nice use of the OpenSCAD workbench making Tech drawings of OpenSCAD models
