Do you guys have any estimated time when a "good enough" solution for the problem will be available?
Thanks ahead,
Infocean
Well my money says its a bug going from OpenSCAD MultiMatrix to FreeCAD Placement Base & Rotation. Anything in a scad script which involves a rotation the CSG process will introduce a MultiMatrix. I am guessing for some rotations it is doing the rotation but omitting the translation to Placement.Base. I don't know if Chris has had any luck tracking things down.
@chennes
I am not a Github person. Is there, or will be there any file I can add to my installation to be able to test? Is it fix to FreeCad or to OpenSCAD? I guess it is to the OpenSCAd Workbench of FreeCAD, but better to know it from the mouth of the horse.
Thanks Chris !!
infocean wrote: ↑Fri May 14, 2021 2:54 am
Thanks Chris !!
Install instructions for the Alternate_Importer are in the README and you can install via Tools | Addon Manager no need for Github
Just have to remember to load file by File | Load and then select which importer when prompted.
