[Ticket #4681] Allow non solid entities to be linked into Bodies in an automagic way.
Pauvres_honteux
Postby Pauvres_honteux » Mon Apr 05, 2021 1:14 pm
I hereby request to allow non solid entities to be linked into Bodies in an automagic way so the user does not need to first create a "link container".
Use case example 1: you have several surfaces outside of the Body which are connected and form a "closed surface" thingie. Now you want this to be made/transformed into a solid inside your Body.
Use case example 2: you have a point on a plane outside of the Body you whish to utilize inside your Body.
Use case example 3: you have a surface outside of the Bodyand now you want to make thickness on/from it inside your Body.
... and so on ...
It would also be nice if the linked geometry could be given an own icon resembling the original geometry with a added "curved arrow" to indicate it originate from somewhere else.
Last edited by Pauvres_honteux on Sun Jun 06, 2021 8:45 am, edited 3 times in total.
openBrain
Re: [Request] Allow non solid entities to be linked into Bodies.
Postby openBrain » Mon Apr 05, 2021 3:26 pm
Subshape Binder
Pauvres_honteux
Re: [Ticket #4681] Allow non solid entities to be linked into Bodies in an automagic way.
Postby Pauvres_honteux » Sun Jun 06, 2021 8:44 am
Feature request: issue #4681 Allow non solid entities to be linked into Bodies in an automagic way.
Postby chrisb » Sun Jun 06, 2021 9:26 am
Pauvres_honteux wrote: Sun Jun 06, 2021 8:44 am Feature request: issue #4681 Allow non solid entities to be linked into Bodies in an automagic way.
You are rather busy today creating feature requests. But please note that these should be discussed in the forum.
