Align axis when Inserting a Part container in a Part container
freedman
Postby freedman » Wed Apr 07, 2021 4:45 pm
If you have two part containers A and B with included bodies, then create a new part container C, then drag (A and B) into C. What should happen? My first thought is A and B should be zeroed on the new C. I'm actually dealing with this issue right now in a macro. I'm asking myself if I should have a button that zeros sub-part containers in the parent part container. It doesn't really matter much until you try to rotate the parent part container, then it becomes a mess.
Re: [Request] File zero / Master zero
Postby chrisb » Wed Apr 07, 2021 8:06 pm
I don't think so. Let's assume you have two part containers with non zero placement. Why do you have them moved? Because they should have a certain relation to each other, e.g. like a chassis and the wheels of a car. If you put them into a new Part you do it because you want to trat them as a unit, and probably with the same relation to each other, e.g. you want to move the chassis with the wheels to their final position.
freedman
Postby freedman » Thu Apr 08, 2021 1:14 am
I wrote, obviously your correct, we should be able to package Parts in Parts so we can create order.
We need a new option! How about If we drag a Part into a Part it would work as it does today but as an option if you drag a Part into a Part but instead hover the mouse over the Origin of the target Part then the inserted Part will be on the Parent axis zero-zero. There could be a pop-up descriptor saying "The part will be inserted at Origin. What do you think?
EDIT: I thought I would try this in 0.20 and tried the option above. It kind of works, I do get some tree response when I try to drop a Part into the Origin of another Part, I get the following error (pic).
Almost.....
Pauvres_honteux
Postby Pauvres_honteux » Thu Apr 08, 2021 4:51 am
@chrisb + @freedman:
What you are chatting about is a separate topic.
Please remove your conversations from about that from this topic into a new topic.
Postby chrisb » Thu Apr 08, 2021 5:06 am
Done
Not sure if I'm speaking of the same issue;
Please rename the subject of the first post appropriately.
freedman
Postby freedman » Thu Apr 08, 2021 7:10 am
The focus of this post is to find a way to allow the user to insert a Part container into a Part container and make it possible to have their axis aligned. Currently the Parent Part when created will start at axis zero-zero but the inserted Part will keep it's position. This is OK sometimes but not if you are creating a new Part, when starting a new Part you want the Parts on the zero axis so that later when we rotate the Parent Part the sub-Parts will rotate around zero.
Often if you include a Part in a Part they can be much distance apart, hard to find even.
Thanks
carlopav
Re: Align axis when Inserting a Part container in a Part container
Postby carlopav » Fri Apr 09, 2021 8:27 pm
maybe offtopic, but reminds something like Std_TreeSyncPlacement
freedman
Postby freedman » Sat Apr 10, 2021 6:24 am
Not offtopic at all, Thank you, thank you. That's what I have been missing and that's also what has been driving me crazy on and off since that option was inserted. I thought all these option settings were about setting how the Tree would display. It's set different on my two machines.
I will say right now I think having an option this powerful should only reside in Preferences, this little one click thing has huge repercussions on how things work, and in a hidden way. If I could compile I would remove this today. It should be turned ON by default. Geeez, I have been trying to figure out what the heck is going on when I move Parts around for weeks. There is a wasted 100 hours at least.
carlopav
Postby carlopav » Sat Apr 10, 2021 7:30 am
Nice. I agree this button Is quite hidden in that position in the toolbar... Id like It to have a more prominent Place in the ui.
Edit. Its very userful to me ti switch It on and off frequently in my workflow
drmacro
Postby drmacro » Sat Apr 10, 2021 9:38 am
Go to Customize and add it to whatever toolbar/s you deem desirable. For tools I use all the time, I use the Global.
I didn't know about the axis selection tools in Sketcher, but when I found them, I added them to Sketcher.
For Global, I have added geometry check and sketch verify, the snip macro, and a couple others for "all the time" access.
Very convenient :mrgreen:
My beginners, written treatise: Learning FreeCAD
