I'm agree with that. No need to make the sketcher too complicated. You can draw a 2D or 3D function outside and then re use it inside a body or sketch. I've wrote a macro from the original 3D parametric Curve.
from __future__ import division
import FreeCAD, Part, Draft
from FreeCAD import Base
from math import *
# Crée un object courbe 3D paramétrique à 5 paramètres:
# X(a,b,c,d,e)
# Y(a,b,c,d,e)
# Z(a,b,c,d,e)
# La courbe est décrite par un nombre de points
# par défaut une spline est crée, un polyline est possible en option
# CreateFace semble buggé... mais est ce vraiment utile? :-D
class MathCurve(object):
def __init__(self, obj):
obj.addProperty("App::PropertyString","a","Parameters","Set a parameter a(t)").a = "1"
obj.addProperty("App::PropertyString","b","Parameters","Set b parameter b(a,t)").b = "0"
obj.addProperty("App::PropertyString","c","Parameters","Set c parameter c(a,b,t)").c = "0"
obj.addProperty("App::PropertyString","d","Parameters","Set d parameter d(a,b,c,t)").d = "0"
obj.addProperty("App::PropertyString","e","Parameters","Set e parameter e(a,b,c,d,t)").e = "0"
obj.addProperty("App::PropertyString","X","Equation","X expression X(a,b,c,d,e,t)").X = "t"
obj.addProperty("App::PropertyString","Y","Equation","Y expression Y(a,b,c,d,e,t)").Y = "a*sin(t)"
obj.addProperty("App::PropertyString","Z","Equation","Z expression Z(a,b,c,d,e,t)").Z = "0"
obj.addProperty("App::PropertyFloat","CurveStart","Curve","Start t").CurveStart = 0
obj.addProperty("App::PropertyFloat","CurveEnd","Curve","End t").CurveEnd = 6.283185
obj.addProperty("App::PropertyInteger","NbPts","Curve","Number of points").NbPts = 20
obj.addProperty("App::PropertyBool","CreateFace","Curve","Wheter to create a face or not").CreateFace = False
obj.addProperty("App::PropertyBool","Close","Curve","close the curve or not").Close = False
obj.addProperty("App::PropertyBool","Wire","Curve","Make a wire instead a Spline").Wire = False
obj.Proxy = self
def onChanged(self, obj, prop):
if prop == "a" or prop == "b" or prop == "c" or prop == "d" or prop == "e" or prop == "X" or prop == "Y"or prop == "Z" or prop == "start" or prop == "end" or prop == "interval" or prop == "createFace" or prop == "close":
self.execute(obj)
def execute(self, obj):
dt = (obj.CurveEnd-obj.CurveStart)/(obj.NbPts-1)
pts = []
t = obj.CurveStart
a = b = c = d = x = y = z = 0
for i in range(obj.NbPts):
try:
value = "a"
a = eval(obj.a)
value = "b"
b = eval(obj.b)
value = "c"
c = eval(obj.c)
value = "d"
d = eval(obj.d)
value = "e"
e = eval(obj.e)
value = "x"
x = eval(obj.X)
value = "y"
y = eval(obj.Y)
value = "z"
z = eval(obj.Z)
except ZeroDivisionError:
print("Warning: Error division by zero in calculus of "+ value +" for t=" +str(t)+" !")
except:
print("Error in the formula of " + value +" !")
pts.append(FreeCAD.Vector(x,y,z))
t += dt
if obj.Close: # pour fermer la courbe on ajoute un point au début
t = obj.CurveStart
a = eval(obj.a)
b = eval(obj.b)
c = eval(obj.c)
d = eval(obj.d)
e = eval(obj.e)
x = eval(obj.X)
y = eval(obj.Y)
z = eval(obj.Z)
if obj.Wire == False:
curve = Part.BSplineCurve(pts)
if obj.Close:
curve.setPeriodic()
if obj.CreateFace:
sh = Part.Face(Part.Wire(curve.toShape()))
else:
sh = curve.toShape()
else:
wire = Part.makePolygon(pts)
if obj.CreateFace == False:
sh = Part.Wire(wire)
else:
sh = Part.Face(wire)
sh.Placement = obj.Placement
obj.Shape = sh
class ViewProviderMath3DCurve(object):
def __init__(self, obj, icon):
obj.Proxy = self
self.icone = icon
self.ViewObject = obj
def getIcon(self):
return self.icone
def attach(self, vobj):
self.ViewObject = vobj
self.Object = vobj.Object
def __getstate__(self):
return None
def __setstate__(self,state):
return None
def MakeMathCurve():
doc = FreeCAD.activeDocument()
if doc == None:
doc = FreeCAD.newDocument()
obj=doc.addObject("Part::FeaturePython","Math3DCurve")
obj.addExtension("Part::AttachExtensionPython","obj")
ViewProviderMath3DCurve (obj.ViewObject, setIconInMacro(""))
MathCurve(obj)
def setIconInMacro(self):
return """
/* XPM */
static char * xpm[] = {
/* width height num_colors chars_per_pixel */
"22 22 8 1",
/* colors */
"` c #000000",
". c #242424",
"# c #484848",
"a c #6d6d6d",
"b c #919191",
"c c #b6b6b6",
"d c #dadada",
"e c #ffffff",
/* pixels */
"aeeeb.beeeeeeeeeeeeeee",
"#eea```#eeeeeeeeeeeeee",
"#ed``a``beeeeeeeeeeeee",
"#ea`beb`.eeeeeeeeeeeee",
"#d`.eee#`beeeeeeeeeeee",
"#b`aeeec`.eeeeeeeeeeee",
"##`ceeee.`ceeeeeeeeeee",
"...deeeea`beeeeeeeeeee",
".`#eeeeec`#eeeeeeeeeee",
"``bfeeeee.`deeeeeeeeee",
"``#aaaaabb`bbaaaaaaaaa",
".aaaaaaabc`#caaaaaa#`#",
"#eeeeeeeee..eeeeeeea`c",
"#eeeeeeeee#`beeeeee.`d",
"#eeeeeeeeea`#eeeeed`.e",
"#eeeeeeeeed``deeeeb`ae",
"#eeeeeeeeeea`beeee.`ce",
"#eeeeeeeeeec`.eeec`.ee",
"#eeeeeeeeeee#`bee#`bee",
"#eeeeeeeeeeec``ba`.eee",
"#eeeeeeeeeeeeb````ceee",
"aeeeeeeeeeeeeeb..ceeee"};
if __name__ == '__main__':
MakeMathCurve()
