[Feature Request] Geometric and mass properties
NewJoker
Post by NewJoker »
it would be great to have an option to obtain the following information about the model using built-in tools (without macros and Python codes):
1) in sketcher (section properties):
- area
- centroid coordinates (with respect to sketcher axes)
- second moments of area (with respect to centroidal axes)
maybe more if possible (like polar second moment of area)
2) on part level:
- volume
- surface area
- center of mass
- moments of inertia (with respect to center of mass)
maybe also moments of inertia with respect to selected point
What do you think?
drmacro
Re: [Feature Request] Geometric and mass properties
Post by drmacro »
NewJoker
Post by NewJoker »
Yeah, I've seen this. It's really nice but maybe something like that could be built into the FreeCAD. Also, this macro won't give me second moments of area for a section.
drmacro
Post by drmacro »
NewJoker wrote: Thu Apr 15, 2021 7:36 pm Yeah, I've seen this. It's really nice but maybe something like that could be built into the FreeCAD. Also, this macro won't give me second moments of area for a section.
Macros can simply be added to the toobar.
Macros can be modified to get second moments.
That what flexibly is all about.
NewJoker
Post by NewJoker »
drmacro wrote: Thu Apr 15, 2021 9:16 pm
Do you know about any ready solutions for that ? I have very little experience with Python programming and maybe someone already made a script for that.
drmacro
Post by drmacro »
I suspect you are correct that it has been done.
mario, who is mentioned in this forum post: https://forum.freecadweb.org/viewtopic.php?t=11290
would probably modify the info macro.
He'll probably pick up on this thread, or you might post in that thread and ask.
kisolre
Post by kisolre »
Part_CheckGeometry shows a lot (if not all) of these.
mario52
Post by mario52 »
hi
my macro (FCInfo) work only with unique object and give "maximum" info of this object
the macro work only outside Sketcher and not inside Sketcher i tray for work inside sketcher but certain dimension hare good and other not then sorry also for my i abandoned this option
for the moment of inertia is other expert user who worked on it see "https://forum.freecadweb.org/viewtopic.php?f=22&t=23888" i am not knowledge for this (my i use only the result give by FreeCAD command) :
m = FreeCADGui.Selection.getSelection()[0].Shape.MatrixOfInertia
if you have concrete formula or other demand and if i can adding it ... no problem
mario
NewJoker
Post by NewJoker »
Thanks for replies. When it comes to FCInfo macro, would it be possible to add an option to calculate and display second moments of area (by clicking on a selected face outside of the sketcher) ? Or does it work only for whole parts (volumes) ?
mario52
Post by mario52 »
hi
FCInfo work for the volume (complete object)
but maybe Part > Create a copy > Create element copy Image Part_ElementCopy (for create a independent face)
and test it ?? I do not know
mario
