the working level auto displayed after the start (the working level will adapt to the current view each time a command is started) corresponds (if I have recognized this correctly) to the setting top / top. this is very confusing in the learning phase.
suggest that the displayed setting be changed to top / top when the program starts.
https://youtu.be/32f0jgdzcCA
[solved] Incorrectly displayed working level when starting the program?
- thomas-neemann
Last edited by thomas-neemann on Sat Jul 31, 2021 10:50 am, edited 2 times in total.
Re: Incorrectly displayed working level when starting the program?
Hast du dazu auch ein Bild? Ich sehe nur ein schwarzes Vorschaufenster.
edit
Sorry, I somehow thought this was posted in the German section. Here is my translation:
Do you have a picture showing what you've described? I'm only seeing a black screen for the video preview.
edit
Regards / Viele Grüße
Max
Max
Not here.thomas-neemann wrote: ↑Sun Apr 18, 2021 6:41 pm corresponds (if I have recognized this correctly) to the setting top / top
Maybe look at:
Edit > Preferences > Draft > General settings > General Draft Settings > Default working plane
Note: 'plane' not 'level'.
- thomas-neemann
With a newly installed system it only happens until the configuration is changed and saved for the first time.
Confirmed. There is a mismatch when there is no value for defaultWP in user.cfg.
DraftGui.py:
defaultWP = Draft.getParam("defaultWP",0)
This value (None) is displayed in the draft Tray.
DraftTools.py:
defaultWP = Draft.getParam("defaultWP",1)
This value (Top) is used to change the actual WP.
DraftGui.py:
DraftTools.py:
OS: Windows 8.1 (6.3)
Version: 0.20.25065 (Git)
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
https://github.com/FreeCAD/FreeCAD/pull/4898
Note that this PR only resolves the mismatch. The default for the defaultWP will be 0 (=None=Auto).
The PR has been merged.
- thomas-neemann
thank you
edit
ok in
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.25541 (Git) AppImage
Hash: ca043dcb6d20d70b8e24d75e810683214eecc5d4
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
