Discussion - Possible way ahead for OpenSCAD hull and Minkowski requests?
duckmug
Re: Discussion - Possible way ahead for OpenSCAD hull and Minkowski requests?
Post by duckmug »
Something offtopic, I came across this addon of yours as well: https://github.com/KeithSloan/toSketch
I've installed it via the addon manager but there is no workbench showing up.
I am on the latest version of Freecad. Is it out of date? That is such a neat concept, not sure how it compares to mesh remodel workbench.
keithsloan52
Post by keithsloan52 »
duckmug wrote: Wed Jun 16, 2021 9:26 am I had no idea that this was around, I am so glad, will be definitely using it.
What makes it restricted to two spheres or two cylinders etc?
Why not support a combination of a cylinder and a cube for instance?
Whilst there are algorithms for Hull of Mesh's not so easy for Brep shapes.
Not easy to make generic, so plan was/is to test for certain cases and hull those.
Cylinder and cube might be possible with lofts but not easy for the generic case where
they may not be aligned, same rotation etc etc.
Anyway have to start somewhere
duckmug
Post by duckmug »
keithsloan52 wrote: Wed Jun 16, 2021 11:47 am
Indeed, I applaud the effort, well worth it.
keithsloan52
duckmug wrote: Wed Jun 16, 2021 10:03 am Something offtopic, I came across this addon of yours as well: https://github.com/KeithSloan/toSketch
Works on my 0.19.1 version
OS: macOS 10.15
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
Locale: C/Default (C)
duckmug
Post by duckmug »
Doesn't work over here, I have the latest freecad version from the freecad repositories on ubuntu.
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: 9e3b630bbfb6807e93eeffb655e6c20f218644fc
Python version: 3.8.5
Qt version: 5.12.8
Coin version: 4.0.0
OCC version: 7.5.1
I followed these steps:
Using Addon Manager
Click on Configure
Enter https://github.com/KeithSloan/toSketch.git
It appeared to have installed fine, but the workbench is nowhere to be seen.
Do you want me to supply anything further?
keithsloan52
duckmug wrote: Wed Jun 16, 2021 11:53 am Doesn't work over here, I have the latest freecad version from the freecad repositories on ubuntu.
Version: 0.19.
Branch: unknown
Qt version: 5.12.8
Coin version: 4.0.0
OCC version: 7.5.1
Using Addon Manager
Click on Configure
While since I used Ubuntu.
Suggest you check your .FreeCAD directory(note the dot). Does it contain a Mod sub directory?
If yes, what sub directories does it have?
You could always goto/create .FreeCAD/Mod and then
git clone https://github.com/KeithSloan/toSketch.git
Worth also checking Report View for startup messages and any errors.
duckmug
Post by duckmug »
This worked!
So I think it is safe to assume something is broken with the addon manager approach.
I think this would have tremendous potential if it was doing automatic recognition of what the contents actually are.
For example right now it recognizes a circle as a bunch of lines instead of a circle.
I suppose the same issue also exist for arcs, curves etc.
Looking at the code, I see that you add circles as circles provided that they are identified as such.
Unfortunately this will not be the case when trying to reverse engineer an stl->step as the circle will be a bunch of lines.
keithsloan52
duckmug wrote: Thu Jun 17, 2021 1:23 am
This worked!
The plan was when a section is/was created a bezier curve fit is performed. Not sure how far I got going down that line.
i.e. where it finds a straight line it becomes a straight line and where n points a bezier curve.
IPowIPi
Post by IPowIPi »
Before opening a new topic for this, just a check whether this is related to this "hull is known not to work in many cases" scenario.
Trying to import the OpenSCAD file below. When importing it with round_corners = false it works, with round_corners = true then FreeCAD throws an error message like that (and renders no object):
18:48:28 End Parser
18:48:28 [<Part::PartFeature>]
18:48:28 End processing CSG file
18:48:28 Traceback (most recent call last):
File "C:\Program Files\FreeCAD 0.19\Mod\OpenSCAD\OpenSCADFeatures.py", line 508, in execute
raise ValueError
<class 'ValueError'>:
Is this normal (because hulls over round shapes aren't supported in general) or more a bug?
My goal is to get a STEP file with round (non-approximated surfaces) from an OpenSCAD file like this.
Edit: Also tested with 0.20 daily and RT stable/daily - same result for all variants.
//OpenSCAD script:
roundness = 5;
round_corners = true; // can be imported in FreeCAD when this is false, an error is thrown during import when true
module rect(width, height) {
translate([-width / 2, -height / 2])
cube([width, height, 1]);
module sphereRect(width, height) {
if(round_corners) {
translate([-width / 2 + roundness, -height / 2 + roundness])
sphere(roundness);
translate([width / 2 - roundness, -height / 2 + roundness])
sphere(roundness);
translate([width / 2 - roundness, height / 2 - roundness])
sphere(roundness);
translate([-width / 2 + roundness, height / 2 - roundness])
sphere(roundness);
} else {
rect(width, height);
hull() {
sphereRect(50, 50);
translate([0, 0, 50])
sphereRect(50, 50);
keithsloan52
I get the same problem with the standard OpenSCAD importer ( importCSG ) in FreeCAD 0.19.1.
Chris @chennes has made some fixes which are in FreeCAD 0.20 but you say you tested 0.20
Are you sure you have the Latest 0.20? Might help to post your FreeCAD information.
Anyway I used the Alternate Importer https://github.com/KeithSloan/OpenSCAD_Alt_Import
and it imported fine
Your code pasted to a scad file
valueError.scad
(726 Bytes) Downloaded 20 times
ValueError.FCStd
(169.3 KiB) Downloaded 22 times
I exported to step but it was not very successful.
ValueError-hull.step
(7.84 KiB) Downloaded 28 times
By changing the FreeCAD STEP preferences for Import/Export so that export used the legacy exporter, I got success
ValueError-hull-2.step
(995.21 KiB) Downloaded 24 times
