Thank you for testing this. The problem is that there is no "master list" of parameters, so we have to have the template files. I think it would be a reasonable future addition to add a hierarchical display of the parameters in those files, however, so that you could individually select the items they contain.bleber wrote: ↑Sat Jul 31, 2021 1:00 am One tnig that is hard to me is the PreferencePackTemplates files. For me the easyest way is if I can select these parameters sirectly in the "create new preference pack" window if Y can see the freecad parameter streucture with a checkbox in front of every parameter. and using the templates for preset checkboxes.
Feedback/ideas needed: "Themes" (now "Preference Packs") User Interface
Re: Feedback/ideas needed: "Themes" (now "Preference Packs") User Interface
So just tried running this myself. Was able to compile and run, but I don't see much functionality yet, at least just on the UI side of everything. Some observations that strike out:
1) On "running" any of the preferences, my recents and examples disappear.
2) I changed the editor fonts to a monospace font (IBM Plex Mono if it matters), and saved a new profile. The font is not loaded back if I run the "classic" pack and then my new "ibm" pack.
3) Perhaps keep some buttons to edit/delete preference packs? Understandably this might be left for later, but it would be helpful to the testers if it's added first.
I apologize in advance if these issues are addressed elsewhere. I'll just go through this thread and maybe have to edit this post
Thanks for testing!
Interesting! I can reproduce this bug, I'll have a look at what's causing it and get a patch submitted. ETA: I think I figured out the problem here, and have patched the PR. If you have a moment to re-test I'd appreciate it!1) On "running" any of the preferences, my recents and examples disappear.
Right now the preference pack templates basically only pull the color information. I'll add the fonts to a separate template file so they can be included when saving. ETA: This is done now as well.2) I changed the editor fonts to a monospace font (IBM Plex Mono if it matters), and saved a new profile. The font is not loaded back if I run the "classic" pack and then my new "ibm" pack.
Thanks for the suggestion, I'll look into it.3) Perhaps keep some buttons to edit/delete preference packs? Understandably this might be left for later, but it would be helpful to the testers if it's added first.
The pleasure is all mine!
I think this bug is fixed, at least for now. Opened a document and it stays in my recents.Interesting! I can reproduce this bug, I'll have a look at what's causing it and get a patch submitted. ETA: I think I figured out the problem here, and have patched the PR. If you have a moment to re-test I'd appreciate it!1) On "running" any of the preferences, my recents and examples disappear.
So I tried doing this, but the new font I set seems to be getting set for ALL the pref packs, including "classic". I didn't look into the xml's themselves though, so this might just be doing nothing for now rather than resetting fonts.Right now the preference pack templates basically only pull the color information. I'll add the fonts to a separate template file so they can be included when saving. ETA: This is done now as well.
Thanks for this. Take your time.Thanks for the suggestion, I'll look into it.3) Perhaps keep some buttons to edit/delete preference packs? Understandably this might be left for later, but it would be helpful to the testers if it's added first.
Any preference pack created prior to this change (including the "Classic Colors") will not include the font information in it, so should not affect fonts -- have you made a new pack that included the font information?jnxd wrote: ↑Wed Aug 04, 2021 11:20 pmSo I tried doing this, but the new font I set seems to be getting set for ALL the pref packs, including "classic".Right now the preference pack templates basically only pull the color information. I'll add the fonts to a separate template file so they can be included when saving. ETA: This is done now as well.
I'm pretty sure I did. I might have to roll back a few commits to test again but I'm pretty sure the "classic" one at least used to change fonts somehow (which you said does not have font info).chennes wrote: ↑Thu Aug 05, 2021 5:02 pmAny preference pack created prior to this change (including the "Classic Colors") will not include the font information in it, so should not affect fonts -- have you made a new pack that included the font information?jnxd wrote: ↑Wed Aug 04, 2021 11:20 pmSo I tried doing this, but the new font I set seems to be getting set for ALL the pref packs, including "classic".Right now the preference pack templates basically only pull the color information. I'll add the fonts to a separate template file so they can be included when saving. ETA: This is done now as well.
EDIT: Just confirming that with your latest commit, even new packs made after setting different font sizes/faces don't make those changes. Only "Editor colors" seem to change. Maybe that's because you haven't put them as a choice in the "make new" dialog?
Oops. Forgot to edit the cMake file to copy the new template! Incoming edit soon…
ETA: OK, new commit actually copies the file.
I only made templates for the properties that I thought it most likely that theme authors would want included. As we see how others want to use the Preference Pack system, it's easy to extend that to include other properties in the template files, but I don't think we'll ever get to a point where those templates are exhaustive (after all, some things really don't belong there, like the recent files and recent macros properties).
In these cases t'he ideal are a import function to scan all user preferències and output a universal template that t'he user can change and Mark the Desired propietes to export.
Mi question is, there are any freecad files that store the propietes to export or read for easy Make a theme pack?
