Forum maintenance today
- kkremitzki
Re: Forum maintenance today
I am working on the attachment problem now, I think I have a solution but it requires re-transferring all of them at about 16GB so it will take a while to see if my hypothesis is correct.
The problem with the "exceeded login attempts" warning should be completely gone now, can you confirm it's still happening today?
Yep, just occurred for me now.kkremitzki wrote: ↑Fri May 14, 2021 3:05 pm The problem with the "exceeded login attempts" warning should be completely gone now, can you confirm it's still happening today?
- kkremitzki
The attachments and login issues should be fixed now. We still have a problem with some of the images displayed in https://forum.freecadweb.org/viewtopic.php?f=3&t=30573 but I think that may be font-related. Additionally there are some holdover problems with the FreeCAD forum theme needing to be updated against phpBB 3.3 breaking changes... but is there anything else?
I will happily remove the icons from the Known OS specific issues, I never liked them, because they caused strange paragraph breakings.kkremitzki wrote: ↑Fri May 14, 2021 4:45 pm The attachments and login issues should be fixed now. We still have a problem with some of the images displayed in https://forum.freecadweb.org/viewtopic.php?f=3&t=30573 but I think that may be font-related. Additionally there are some holdover problems with the FreeCAD forum theme needing to be updated against phpBB 3.3 breaking changes... but is there anything else?
Done.chrisb wrote: ↑Fri May 14, 2021 5:27 pm I will happily remove the icons from the Known OS specific issues,
Thanks! Now i see older pictures. But i had a new issue: i can not upload files or pictures. I would like to show the message, but i cant because of this. The error message is:
Thanks for working on it!
Greetings
user1234
Could not upload attachment to ./files/9411_10363232a438e429679cd38d133dce42.
Greetings
user1234
- kkremitzki
Should be fixed now.user1234 wrote: ↑Fri May 14, 2021 6:00 pm Thanks! Now i see older pictures. But i had a new issue: i can not upload files or pictures. I would like to show the message, but i cant because of this. The error message is:Thanks for working on it!Code: Select all
Greetings
user1234
Hello!
Greetings
user1234
Confirmed, works now, thanks for fast fixing!
Greetings
user1234
This is now fixed again, see this thread: https://forum.freecadweb.org/viewtopic. ... 25#p503743
I apologize for the delay in replying, but I've been out of office for a few days.kkremitzki wrote: ↑Thu May 13, 2021 10:33 pm ...................
.........I just made a change, is this problem fixed for you now?
Yes, now it works great (!) Everything is back to work perfectly, I confirm the speed increase, compared to before you notice a lot.
Thanks for the great work !!
