Forum maintenance today
- kkremitzki
Re: Forum maintenance today
The navbar links are broken because of breaking changes in the Prosilver theme for phpBB 3.3, the FreeCAD and FreeCAD-Dark themes are based on this so they will need to be updated with a proper solution. For now I have deployed a hacky fix for the header and footer. Someone also mentioned that freecadweb.org/manual was broken, so I fixed that as well as freecadweb.org/api.
- kkremitzki
One of the benefits of completing this migration is that the forum is now available via HTTP/2 which should mean a big speedup as mentioned, although since things have been extra slow the last few days it might be tough to get a true gauge for how much faster things are without doing actual measurement.
Hello!
Thanks for working on it.
Greetings
user1234
I have the same issue. I only see images from this week.kkremitzki wrote: ↑Thu May 13, 2021 2:05 pmAnother person has reported attachments/images not showing, which I'm looking into as well.
Greetings
user1234
- kkremitzki
Thank you. I just made a change, is this problem fixed for you now?domad wrote: ↑Thu May 13, 2021 5:14 pm I point out that the Italian translation still does not work even if the chosen language is Italian.
Before the update they were in Italian.
The forms continue to be in English only.
I noticed a notable increase in speed (almost immediate page change and login).
Firefox browser version 88.0.1 (64 bit)
Thanks for the great work of improvement !!!
Italian works now, and so does German and others I tried.
However, old images are still missing, see e.g. the Bug submission guidelines, which start with an image, or this post: https://forum.freecadweb.org/viewtopic.php?f=3&t=58426 where the images are missing, while the attached FreeCAD file is available.
Feedback: The forum now is much faster than it ever was - thanks for that!
(Old images are still missing).
The forum is basically back to normal and faster...but, why am I prompted that I've exceeded login attempts and asked for the secret handshake every time I login???
