Screw Impeller Example
schupin
Re: Screw Impeller Example
Postby schupin » Wed Jun 02, 2021 9:27 pm
ppemawm wrote: Sat May 29, 2021 8:32 pm I have simplified the model to be more suitable for your use. The variable input now consists of only geometry:
Very nice modeling as usual !
It's the first time I see a "Variables" object on the tree view : where does it come from ?
(usually I use spreasheets but these variables looks easier to use to me : no extra window to the spreadsheet)
user1234
Postby user1234 » Wed Jun 02, 2021 10:04 pm
Very nice! That is a powermodel!
ppemawm
Postby ppemawm » Wed Jun 02, 2021 11:58 pm
schupin wrote: Wed Jun 02, 2021 9:27 pm It's the first time I see a "Variables" object on the tree view : where does it come from ?
The add/delete variables tool can be found in the Assembly4 workbench toolbar. ( Note: In the attached file I first created a new Assembly4 Model then deleted "Model" in the Assembly4 file and kept "Variables".)
You can also achieve something similar with the Dynamic Data add-on.
user1234
Postby user1234 » Thu Jun 03, 2021 11:51 pm
It is possible without a addon or macro. Just add for example a textdocument (Tools --> add text document), show all properties in the property view and add a property. Then you can access it like all expression. Just differ Input and Output. The same document can not do both (circle dependencies). The only properties what i missing at the moment are density and mass (i do it per float, but it is not really correct).
Greetings
user1234
schupin
Postby schupin » Sun Jun 06, 2021 7:02 pm
ppemawm wrote: Wed Jun 02, 2021 11:58 pm The add/delete variables tool can be found in the Assembly4 workbench toolbar. ( Note: In the attached file I first created a new Assembly4 Model then deleted "Model" in the Assembly4 file and kept "Variables".)
user1234 wrote: Thu Jun 03, 2021 11:51 pm It is possible without a addon or macro. Just add for example a textdocument (Tools --> add text document), show all properties in the property view and add a property. Then you can access it like all expression. Just differ Input and Output. The same document can not do both (circle dependencies). The only properties what i missing at the moment are density and mass (i do it per float, but it is not really correct).
Thank both of you !
