Version 0.19 TechDraw problem
Since there are many new functions in version 0.19, I would like to use them. However, in plans created in 0.18, all font sizes are now smaller from 5mm to 3.5, from 3.5 to 2.5mm. I also have problems with the parts lists I have inserted: The line height of the spreadsheets is now much higher.
Even if you create a new plan in 0.19, the font size is not correct. I also noticed that editable texts in templates are no longer where they should be.
Does anyone have these problems too?
Best regards
Best regards
Re: Version 0.19 TechDraw problem
Could you share an example file and some Screenshots as comparison? Could it be that TD adopted your current settings?
Regards / Viele Grüße
Max
Max
Unfortunately the problem persists.
Here is a screenshot
Best regards
OS: Windows 10 Version 2009
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: German/Austria (de_AT)
Best regards
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
The file doesn't seem to be too big, and it's a hassle for me - and probably for others too - to open rar files. Please attach the FreeCAD file to the post.
- wandererfan
I don't have a copy of v0.18, but I don't think I'm following. If I look inside your file, the dimension text is specified as 2.5mm.
<ViewProvider name="Dimension" expanded="0">
<Property name="Fontsize" type="App::PropertyLength">
<Float value="2.5000000000000000"/>
</Property>
Your template looks fine in v0.19.Pafnutij wrote:I also noticed that editable texts in templates are no longer where they should be.
I think this is the problem:
In V0.18 (see attached image) the Annotation with the Text Size of 7mm is larger than in V0.20. In V0.20 the letter T seems to be 5mm tall, instead of 7mm.
- td-text7mm-v018.png (6.88 KiB) Viewed 1497 times
Maybe move this to the TechDraw forum?
Done.
