Discussion on placement
edwilliams16
Re: Discussion on placement
Post by edwilliams16 »
from FreeCAD import Vector
def circumcenter(A, B, C):
    '''Return the circumcenter of three 3D vertices'''
    a2 = (B - C).Length**2
    b2 = (C - A).Length**2
    c2 = (A - B).Length**2
    if a2 * b2 * c2 == 0.0:
        print('Three vertices must be distinct')
        return
    #compute barycentric coordinates of circumcenter
    alpha = a2 * (b2 + c2 - a2)
    beta = b2 * (c2 + a2 - b2)
    gamma = c2 * (a2 + b2 - c2)
    return (alpha*A + beta * B + gamma * C)/(alpha + beta + gamma)
Here's some code to compute the circumcenter of three vertices if you want to play with it. The error checking may not be appropriate.
edwilliams16
debug = True
        return
selt = Gui.Selection.getSelectionEx()
if len(selt) != 1:
    print('Select one vertex, edge or object')
    shift = App.Vector(0, 0, 0)  # bail and do nothing
else:
    sel = selt[0]
    if sel.HasSubObjects:
        vv = sel.SubObjects
        if len(vv) ==3 and vv[0].ShapeType == 'Vertex' and   vv[1].ShapeType == 'Vertex' and vv[2].ShapeType == 'Vertex':
            shift = circumcenter(vv[0].Point, vv[1].Point, vv[2].Point)
            if debug: print('Three Vertices')
        else:
            selected = sel.SubObjects[0]
            if selected.ShapeType == 'Vertex':
                shift = selected.Point
                if debug: print('One vertex')
            elif selected.ShapeType == 'Edge':
                if selected.Curve.TypeId == 'Part::GeomCircle':    #circles and arcs
                     shift = selected.Curve.Center
                     if debug: print('One arc')
                elif selected.Curve.TypeId == 'Part::GeomLine':
                    shift = (selected.valueAt(selected.FirstParameter) + selected.valueAt(selected.LastParameter))/2 # mid-point
                    if debug: print('One line')
                else:
            elif selected.ShapeType == 'Face':
                shift = selected.CenterOfMass #center of face
                if debug: print('One face')
            else:
    else:
        if debug: print(f'ObjectName is {sel.ObjectName}')
        #if sel.ObjectName[0:11] == 'BaseFeature':
        if hasattr(sel.Object, 'Shape'):
            if debug: print('One solid')
            if sel.Object.Shape.ShapeType == 'Solid':
                shift = sel.Object.Shape.CenterOfMass
            elif sel.Object.Shape.ShapeType == 'Compound':
                shift = sel.Object.Shape.SubShapes[0].CenterOfMass
            #more cases?
            else:
        else:
if debug: print(f'Shift = {shift}')
base = App.ActiveDocument.getObject(sel.ObjectName).Placement
base.move(-shift)
I added the three vertices -> move to center of circle option. The nested if's are getting a bit out of hand...
As before import and make solid, then make a BaseFeature of the solid in a body. Then either pick one vertex. one line, one arc or the whole solid, OR now three vertices. Then run the macro.
EDIT The macro worked more generally than expected. With an added tweak it now seems to work for STL imports that have been processed with Part|Create Shape from Mesh. It does not need to be put in a Body container or even converted to solid. Sorry so many "progress" posts.
Question. Are there more ShapeTypes to deal with other than Solid and Compound?
drmacro
Post by drmacro »
edwilliams16 wrote: Sun Jun 13, 2021 9:05 pm ...
Seems to work.
As for more types...good question. :)
drmacro
Post by drmacro »
And...right after I sent the last post this from another post with essentially a list of them all ...maybe?
https://github.com/MariwanJ/Design456/b ... eak.py#L98
Note: not saying they all need to be processed, just I had no list before... :mrgreen:
edwilliams16
debug = True
'''Usage:
This macro will adjust the placement of a shape to place a selected feature at the origin.
One vertex:  - to origin
One line segment - midpoint to origin
One circle - center to origin
One arc of circle - center to origin
One face - CG of face to origin
Three vertices - center of circle through vertices to origin
Shape - CG of shape to origin
If the shape is a BaseFeature inside a body, the base feature's placement in the body is adjusted.
        return
def centerofmass(subshapes):
    mass =0.0
    moment = App.Vector(0, 0, 0)
    for sh in subshapes:
        mass += sh.Volume
        moment += sh.Volume * sh.CenterOfMass
    return moment/mass
if len(selt) != 1:
    print('Select one vertex, edge or object\nor three vertices for center of circle')
else:
    sel = selt[0]
        vv = sel.SubObjects
        elif len(vv) == 1:
                else:
                    print(f'edge is {selected.Curve.TypeId} not handled')
            else:
                print(f'ShapeType {selected.ShapeType} not handled')
        else:
            print('Wrong number of Selections')
    else:
            shape = sel.Object.Shape
            if shape.ShapeType == 'Solid' or shape.ShapeType == 'Shell':
                shift = shape.CenterOfMass
            elif shape.ShapeType == 'Compound' or shape.ShapeType == 'CompSolid':
                shift = centerofmass(shape.SubShapes)
            #more cases?
            else:
                print(f'Object ShapeType {sel.Object.Shape.ShapeType} not handled')
        else:
            print(f'{sel.ObjectName} is not a shape')
base.move(-shift)
The macro now handles ShapeTypes: Solid, Shell, Compound and CompSolid, computing the CG of composite objects.
It will use a single vertex, the mid-point of a line, the center of a circle or arc or the CG of a face as the reference point to move to the origin.
It will do nothing with B-splines and Wires.
There's no Undo - but the restoring shift is printed to the report view. Undo would be better if I figured how to do it.
Maybe approaching prime-time with user testing? Should I link to new thread in Python Scripting and Macros?
drmacro
Post by drmacro »
Hmm...I have not attempted an Undo.
But I think there is call to get snapshot of the Undo stack, before you begin. Then another call to mark the end of the operation and it puts it on the stack...but I'm winging it based past non-FreeCAD experiences. ;)
As for posting in the scripting forum, more eyes are probably better.
I tested the macro: works great! It does more than I need.
Pauvres_honteux
Post by Pauvres_honteux »
Any chance this can be made to "remember" the moved stuffs original position?
If so, this would in a wiff become the almighty Move-tool we so badly need.
drmacro
Post by drmacro »
Pauvres_honteux wrote: Thu Jun 17, 2021 9:34 am Any chance this can be made to "remember" the moved stuffs original position?
Have you actually read the entirety of this thread?
The initial issue is that the original position is not forgotten when something is moved before it is moved into a body. :? :lol:
Pauvres_honteux
drmacro wrote: Thu Jun 17, 2021 10:09 am Have you actually read the entirety of this thread?
Okey, I see how my quest can be misread here.
Let us imagine I envision a broader scope so to say.
Expressing myself differently, this Move-tool I was whishing for would then be functional for anything, not only solids.
It est, it shall remember the original position for anything the user whish to move.
