Multiple equality constraints
Michelle
Post by Michelle »
Hello why can't equality constraint be applied to more than two features? For example when using the "constraint preserving fillet" on four corners, I get equality "41" "41, 42" "42, 43" and "43". Why not "41" for all of them? Thanks!
Re: Multiple equality constraints
Hi and welcome to the forum!
What are you talking about? Sketcher? Assembly? If the latter, A2plus or Assembly 3 or 4?
Michelle wrote: Wed Jun 16, 2021 2:17 amwhy can't
The most common answer to such a question is that it is not implemented yet and waits for an eager developer who will do it without any payment.
Michelle
Post by Michelle »
Hello Chris, I'm referring to the sketcher equality constraint
drmacro
Post by drmacro »
I suspect they are applied sequentially in the solver matrix, thus represented as you show.
The current system has the advantage that it is easy to see how many degrees of freedom are consumed by which constraint. And for the solver these have to be separated anyway.
