If the collision controller is added to the sketch area, you can facilitate some basic designs.
https://twitter.com/tc_ulgen/status/1405139682917289989
Sketcher add a collision detection request
Re: Sketcher add a clossion dedection request
Please add [Feature Request] to the title of the thread. Please also a 3-4 more lines explaining the feature in more depth. (Not everyone will click on the clip or fully understand what you're trying to achieve)
Looks like a request for adding tangents to sketcher?
The sketch section has a very strong analysis. Sometimes in 2-dimensional mechanical designs, the collision inspection will be added to be added to designing or designing mechanisms. for example the two of the two circles. Thus the movement of the mechanism is better visible. thus making better mechanism design. you can add left menu clossion dedection radiobox.
- Ekran görüntüsü 2021-06-22 09545444.png (319.85 KiB) Viewed 1327 times
Sorry, but it is still not clear to me what this collision detection should do. Is it an animation?
BTW: Could you please correct the typos in the subject of the first post, as it is used by search engines as the title of the topic.
If I understand this discussion, this is an attempt to use the solver as an animation/collision (linkage kinematics) tool.
If that is so, I believe it is what I often see as a misunderstanding of what the sketcher is meant to be.
From the Sketcher wiki first paragraph: "The FreeCAD Workbench Sketcher Workbench is used to create 2D geometries intended for use in the Workbench PartDesign.svg PartDesign Workbench, Workbench Arch.svg Arch Workbench, and other workbenches."
Linkage kinematics is typically shown as lines riding/anchored to other lines and detection of lockups, etc. is analyzed.
While the lines and constraints in Sketcher resemble this, and the math of the solver may be similar, linkage analysis is a particular field and certainly not what Sketcher is intended to address.
A specific workbench, IMO, would be a better approach. Rather than attempting to shoehorn features of other disciplines into Sketcher. (And, may be addressed by some of the work that has been done with assembly workbenches...)
Re: Sketcher add a collision detection request
I think one can use Sketcher pretty well to simulate 2D kinematics. I use this in combination with Asm4 and I'm quite impressed with the results.
In order to have a real ridged body simulation, please take a look at the "Dynamics" Workbench currently in development. Discussion at https://forum.freecadweb.org/viewtopic.php?f=18&t=39165
I can use a hammer to put in a bolt as well...doesn't mean I should or that the hammer is the most effective tool for the job.
Sketcher can be helpful in some cases, but there has to be invested quite some time to detect and report collision, but what is wouldn't be a general solution abyway, because the sketcher is strictly 2D.
