Choose which workbeches load at start up [Feature Request]
- adrianinsaval
Re: Chose which workbeches load at start up [Feature Request]
nice job! I would center the check-boxes within their column and omit the question mark in the header
Excellent !!! I'm wondering if "Autoload" is clear enough : what do you think about "Load at start-up" ?
I had the same thought -- I agree that's clearer, but it's also longer. Maybe if I let the label wrap to two lines? I haven't tried it, I don't know what that will look like.
- adrianinsaval
or just explain in a tooltip for the checkboxes if that's not too complex
I think most people would be confused only once, if that much.
Gene
Gene
OK, here's another draft, incorporating those suggestions:
For completeness, here's the interface I submitted in that PR:
I left the old (circa 2004) autoload preference alone (see the Start workbench in the interface above), and just disabled the checkbox for that item, with a tooltip that tries to explain the situation:
kkremitzki wrote: ↑Sat Aug 07, 2021 3:51 pm <wmayer> There are others who have the capacity to merge those changes, for example, ...
so .... following through on all this, do you have the technical (administrative) possibility to merge this PR ? Would you - please - be willing to take the responsibility to do it ?kkremitzki wrote: ↑Sun Aug 08, 2021 12:10 am <wmayer> Last forum visit for him was back on July 27th, a little more than a week ago, for what it's worth...
I hope you are asking @kkremitzki -- I certainly don't! That said, I'm sure it would help if a couple of people reviewed the PR on GitHub. I'd love a few testers to build it and make sure it works properly, especially on Linux and Mac.
