SpacePilot Pro buttons are not working
I use a 3dconnexion SpacePilot Pro in linux and navigation work well but the buttons do not. The 3DConnexion.xml file list the same keycode twice, one for a short press and one for a long press. On my machine I get different keycodes when doing a short press vs a long press.
I can fix the definitions and make it work for me in Linux but maybe it work differently on Mac/Windows and would break over there? Is there anyone here that use a SpacePilot Pro where the buttons work (in any OS)?
/Dennis
/Dennis
Re: SpacePilot Pro buttons are not working
I have a "normal/small" SpaceMouse and the buttons are working. Can we get some more information? Which Linux, which FC version, which driver, do you know if the system recognizes the buttons?
Regards / Viele Grüße
Max
Max
Well, the button works but generate different keycodes than what is listed in the xml file in Freecad.
For example, in Freecad it is defined (for SpacePilot Pro) as:
but here the button labeld R/L generate KeyCode 4 on short press (R) and KeyCode 3 on long press (L). If I update the XML with the correct values from my system all works well. I also don't see any code that make use of the DownTime property in FC so unless I miss something it look like it can't work for buttons with two operations on them.
This is on a Fedora 33. Both in FC 0.19 and the master branch from git and using spacenavd that came with Fedora 33.
/Dennis
<Map Description="Right" KeyCode="4" DownTime="short" Command="Std_ViewRight"/>
<Map Description="Left" KeyCode="4" DownTime="long" Command="Std_ViewLeft"/>
/Dennis
hm, so what is future proof would be a macro or similar that is picking up the machine specific congfig then, if the provided defaults does not map correctly?
like one of those "calibration" screens where the user can connect movement and button presses for their particular set-up.
just a random thought...
The idea of a long press detection would be nice too indeed
Max
Max
With these changes the SpacePilot Pro works fine on my system:
https://github.com/FreeCAD/FreeCAD/pull/4924
Maybe it can help others that have the same device as well.
Can anyone else with a SpacePilot Pro test the proposed changes?
I might be able to borrow one. I'll see what I can do.
Max
Max
Looks like I'm going to get one but I can't say when. Currently all "free" units are in use. I have to wait.
Max
Max
I was able to borrow one
Now I've to look into compiling FreeCAD myself. I haven't done that so far (I'm on Linux).
Max
Max
