[Features Requests] Sketcher Radius/Diameter presentation
Re: [Features Requests] Sketcher Radius/Diameter presentation
Just wandering will those parameters appear under Parameters or need to be manually created?
For me personally it makes it a lot easier to select, double-click and move the constraints when they are not all on top of each other (demo with 5 degrees in Preferences).
I understand the need for moving the indicator and text. What I don't understand is the "random" element.
I would want the same behavior every time, not some random behavior. Perhaps I do not understand what you mean by "random".
Gene
Gene
This is the second image from @Syres. If you use to have concentric dimensions, they are easier to see/drag if some randomness is added in the display angle.
Notice that this is disabled by default.
Is there an easy way to find those parameters that are absent but used if present? Because some "random" mention somewhere (like this thread) would be quite hard to find/search for.
When I introduce such parameters, I always document them in Fine-tuning as soon as the PR is merged.
Hi.
I think a good way of choosing the inclination of the text of the radius/diameter measurement would be that of the line passing through the center of the circle and the point clicked by the user when selecting the circle.
I have uploaded many FreeCAD video tutorials to my YouTube channel
- Shalmeneser
This idea is similar to the Fillet (the radius depends on the distance between the vertex and where you click on the line).
But, if you select the circle in the combo view, there is no point selected.
...then there could be a default value for setting the inclination...Shalmeneser wrote: ↑Sat Jul 31, 2021 5:37 pm ...But, if you select the circle in the combo view, there is no point selected.
