Testing Topological Naming (as requested by @wmayer)
For those who aren't aware, wmayer publicly has asked for help testing @realthunder's Topological Naming PR which is also part of his LinkStage3 branch. Citation (link)
Unless you're a power user and feel comfortable compiling the Topological Naming PR from source, there is no easy way for users to test the Toponaming branch other than using the realthunder's Daily build
Therefore, I'm also interpreting wmayer's request as testing @Realthunder's LS3 branch available from https://github.com/realthunder/FreeCAD_ ... 3/releases since he's constantly fixing bugs reported by users. Those bug fixes that are related to Toponaming have been and will be added to the open TopoNaming PR.
Note: We're not sure where wmayer is ATM but the least we can do is help him tackle this by trying to break RTs toponaming algorithm and report back.
I invite every power user to test the realthunder branch during the next several weeks. I also invite any user to test the LinkStage3 branch. Please respond below. Thanks!
Edit: reworded for clarity.
Edit2: For those worried about their configuration files (user.cfg & system.cfg being corrupted: it's a good habit to back them up (Use the macro named: Macro_findConfigFiles to locate your config files and then back them upmanually). The LinkStage3 branch writes it's own separate config files (in order to avoid clashing with the main FreeCAD master branch, they are stored in the same location only difference is they have link prepended to them: link.user.cfg & link.system.cfg
Re: LinkStage3 Testing (as requested by Werner)
Here is a first observation: In the realthunder version (subsequently abbreviated with RT) the GUI reacts very slow. To be seen especially when turning an object in 3D view.
RT: 6.5 frames per second
Master: 60 frames per second
RT:
OS: macOS 11.2
Version: 2021.717.24301 +3842 (Git)
Branch: LinkDaily
Hash: 44be6d539871be4083e83f428e8fcfbcf38408ef
Python version: 3.9.4
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/Germany (en_DE)
Master:
OS: macOS 10.16
Version: 0.20.25311 (Git)
Hash: c5524bb58a7126fa2242d6137eb82ee9d54e82d4
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
RT:
OS: macOS 11.2
Branch: LinkDaily
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Master:
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.2
Make sure you're using his Daily build.
It may be the reason he implemented the experimental render engine that bypasses coin3d and uses Diligent Engine
Try enabling it Preference -> Display -> Render cache -> Experimental
ref: https://forum.freecadweb.org/viewtopic. ... 50#p495950
That's what I'm testing.
Slight improvement, but still far from master.It may be the reason he implemented the experimental render engine that bypasses coin3d and uses Diligent Engine
RT: 7.7 FPS.
Next difference:
Realthunder uses Windows style panel decorations, while Mac users usually want the Mac style (for all the money they have payed for their computers).
RT: Master:
RT: Master:
Loading the SheetMetal object from this post shows errors if the suggested recompute on loading is done. It shows only warnings without the recompute. The model loads fine in master
14:35:47 <PropShape> PropertyTopoShape.cpp(412): Pending recompute for generating element map: forum_sheetmetal_offset#Body
14:35:47 <PropShape> PropertyTopoShape.cpp(412): Pending recompute for generating element map: forum_sheetmetal_offset#Box
14:35:47 <PropShape> PropertyTopoShape.cpp(412): Pending recompute for generating element map: forum_sheetmetal_offset#Bend
14:35:47 <PropShape> PropertyTopoShape.cpp(412): Pending recompute for generating element map: forum_sheetmetal_offset#Bend001
14:35:47 <PropShape> PropertyTopoShape.cpp(412): Pending recompute for generating element map: forum_sheetmetal_offset#Bend002
14:35:51 Traceback (most recent call last):
File "/Users/cb/Library/Preferences/FreeCAD/Mod/sheetmetal/SheetMetalCmd.py", line 1067, in execute
thk = sheet_thk(Main_Object, face[0])
File "/Users/cb/Library/Preferences/FreeCAD/Mod/sheetmetal/SheetMetalCmd.py", line 304, in sheet_thk
selItem = MainObject.getElement(selFaceName)
<class 'ValueError'>: Shape index 36 out of bound 10
14:35:51 Recompute failed! Please check report view.
Re: LinkStage3 Testing (as requested by @wmayer)
Just wondering -
Is this something that relative newcomers can try out as well by downloading something that is already built and that won't bork their freecad configuration file and other aspects of the main branch they are using/learning with? Obviously they have to be somewhat more than a brand new noob to understand the topo issue and how to avoid/trigger it in the main branch.
I believe this is the link, latest release is at the top of the page, the files are a little ways down. Correct me if wrong and I will edit this post.
I will work on this as much as I can. Thanks
that is the latest of the rt branch, right? is that what wwmayer was referring to?freedman wrote: ↑Thu Aug 05, 2021 11:22 pm I believe this is the link, latest release is at the top of the page, the files are a little ways down. Correct me if wrong and I will edit this post.
how does that relate to being merged with main since it's not merged with main?
One of the quirks of FreeCAD is that the same user configuration files are used for all FC installations. It is possible to select alternates with a command line start, but if you don't specifically do that then there could be some corruption to your standard files.
In any case, I would save the user.cfg and system.cfg files before trying a totally new version.
Gene
