While selecting Axis for a PolarPattern I wanted to select an arc from a sketch instead of the generated edge (does not work - see comment below). But there is some automation involved that prevents that. Upon selecting "Select reference" the parent feature is automatically displayed and this obstructs the sketch, making selecting the overlapped sketch edge impossible. Trying to "select and show/hide something in the treeview while in "Select reference" mode just complains that "Selection not allowed by filter.
So either making this automation optional or handling the treeview clicks independent of the mode would be better IMO.
comment: Using Sketch arc/circle as reference does not actually work. I manually entered the desired edge and got an error "gp_Dir() - input vector has zero norm". Then tried a circle from another sketch - same. Still selecting a shape edge as soon as it is generated would have been better in light of TNP.
[FR] Allow toggling visibility while in "Reference selection" mode.
Re: [FR] Allow toggling visibility while in "Reference selection" mode.
The visibility automation is indeed sometimes annoying. Did you try this in 0.20?
Wirefame works to select sketch lines inside a solid.Trying to "select and show/hide something in the treeview while in "Select reference" mode just complains that "Selection not allowed by filter.
I see the same in 0.20 25311error "gp_Dir() - input vector has zero norm".
There certainly are some things that are weird, locked out of tree, no single solid error if the polar is incorrect.
