Crowdin does not allow you to upload *.ts directly from the link. Write this program is not to be able.
How regularly is the archive with translations in crowdin updates?
Re: How regularly is the archive with translations in crowdin updates?
I don't think it's necessary to upload, just to download. Can't we just add something like
LANG_CODE = "bg"
import urllib.request
with urllib.request.urlopen(f'https://crowdin.com/backend/download/project/freecad/{LANG_CODE}.zip') as response:
zip_data = response.read()
We can and it works. But kisolre wants an archive with the latest changes. And if you download the archive in the way you suggested, there will still be translations from September 6, and today is already the 13th. Recent translations can be downloaded only one file at a time through the Crowdin interface. Although the method you proposed is good for saving traffic.chennes wrote: ↑Sun Sep 12, 2021 8:31 pmI don't think it's necessary to upload, just to download. Can't we just add something likeCode: Select all
LANG_CODE = "bg" import urllib.request with urllib.request.urlopen(f'https://crowdin.com/backend/download/project/freecad/{LANG_CODE}.zip') as response: zip_data = response.read()
I think you can download fresh translations only manually, then throw them into \ts folder and the my script will do everything by itself.
Maybe there is something like in the Crowdin REST API?:
https://crowdin.com/backend/download/project/freecad/ru/Arch.ts
I'm look REST API of Crowdin.
May be that?
https://support.crowdin.com/ru/api/pre-translate/
Is possible to send POST request from FreeCAD? And get response?
Make sure you are using APIv2: https://support.crowdin.com/api/v2/
And yes, you can use Python to sent a POST request, so if you wanted this to be a FreeCAD WB that would be possible.
ETA: In particular, this looks promising... https://support.crowdin.com/api/v2/#ope ... files.post
I think there is no such possibility through the REST API...
As far as I can tell, you can access every single feature of CrowdIn through the API -- in this case, sending a POST request to:
with a payload like:
Should give a response like:
where that url is a location you can download the translation from. Presumably there's an API call to get a list of the fileIDs, but I haven't looked for it yet. Did this not work for you? I haven't tested it, but it certainly looks from the documentation like exactly what we need.
https://crowdin.com/api/v2/projects/freecad/translations/builds/files/{fileId}
"targetLanguageId": "bg",
"exportAsXliff": false,
"skipUntranslatedStrings": false,
"skipUntranslatedFiles": false,
"exportApprovedOnly": false
"data":
"url": "https://production-enterprise-importer.downloads.crowdin.com/992000002/2/14.xliff?response-content-disposition=attachment%3B%20filename%3D%22APP.xliff%22&X-Amz-Content-Sha256=UNSIGNED-PAYLOAD&X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIGJKLQV66ZXPMMEA%2F20190920%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20190920T093121Z&X-Amz-SignedHeaders=host&X-Amz-Expires=3600&X-Amz-Signature=439ebd69a1b7e4c23e6d17891a491c94f832e0c82e4692dedb35a6cd1e624b62",
"expireIn": "2019-09-20T10:31:21+00:00",
"etag": "ebd69a1b7e4c23e6d17891a491c94f832e0c82e4692dedb35a6cd1e624b62"
Better if you showed code on python... instead requests and response.chennes wrote: ↑Mon Sep 13, 2021 2:01 am As far as I can tell, you can access every single feature of CrowdIn through the API -- in this case, sending a POST request to:with a payload like:Code: Select all
Should give a response like:Code: Select all
{ "targetLanguageId": "bg", "exportAsXliff": false, "skipUntranslatedStrings": false, "skipUntranslatedFiles": false, "exportApprovedOnly": false }
where that url is a location you can download the translation from. Presumably there's an API call to get a list of the fileIDs, but I haven't looked for it yet. Did this not work for you? I haven't tested it, but it certainly looks from the documentation like exactly what we need.Code: Select all
{ "data": { "url": "https://production-enterprise-importer.downloads.crowdin.com/992000002/2/14.xliff?response-content-disposition=attachment%3B%20filename%3D%22APP.xliff%22&X-Amz-Content-Sha256=UNSIGNED-PAYLOAD&X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIGJKLQV66ZXPMMEA%2F20190920%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20190920T093121Z&X-Amz-SignedHeaders=host&X-Amz-Expires=3600&X-Amz-Signature=439ebd69a1b7e4c23e6d17891a491c94f832e0c82e4692dedb35a6cd1e624b62", "expireIn": "2019-09-20T10:31:21+00:00", "etag": "ebd69a1b7e4c23e6d17891a491c94f832e0c82e4692dedb35a6cd1e624b62" } }
from urllib import parse, request
data ={
"exportAsXliff": False,
"skipUntranslatedStrings": False,
"skipUntranslatedFiles": False,
"exportApprovedOnly": False
data = json.dumps(data)
data = parse.urlencode(data).encode()
req = request.Request("https://crowdin.com/api/v2/projects/freecad/translations/builds/files/549", data=data) # this will make the method "POST"
resp = request.urlopen(req)
And where get {fileId}?
Other variant:
import requests
import json
url = "https://crowdin.com/api/v2/projects/freecad/translations/builds/files/549"
body ={
headers = {'content-type': 'application/json'}
req = requests.post(url, data=json.dumps(body), headers=headers)
print(req.text)
I'm just pasting in information from the documentation:
That page says you get the file ID from the List Files command:
https://support.crowdin.com/api/v2/#ope ... es.getMany
I understand this.chennes wrote: ↑Mon Sep 13, 2021 2:08 pm I'm just pasting in information from the documentation:
import requests
import json
url = "https://crowdin.com/api/v2/projects/286/files"
body ={
print(req.text)
And if I understand correctly, the user must create a token in the profile. A fairly complex script.
Of course, it is convenient when everything is done with one button, but I am not so familiar with the Crowdin API...
And diving into this API may take a lot of time...
It's probably better to make do with what we have for now.
