Self-intersection is not detected when intersecting triangles are on the same plane
m3g1dd0
Postby m3g1dd0 » Mon Aug 30, 2021 10:29 am
2D: co-planar
I use the following simple ASCII STL file as input for self-intersection mesh repair. It's basically five triangles on the same plane i.e. co-planar. Triangle `4` is intersecting with triangle `1`. FreeCAD cannot detect the self-intersection of facets `4` and `1`.
solid Simple
facet normal 0.0e0 0.0e0 1.0e1
    outer loop
        vertex 0.0e1 0.0e1 1.0e1
        vertex 0.0e1 +1.0e1 1.0e1
        vertex +1.0e1 0.0e1 1.0e1
    endloop
endfacet
    outer loop
        vertex 1.0e1 1.0e1 1.0e1
    endloop
endfacet
    outer loop
        vertex -1.0e1 1.0e1 1.0e1
    endloop
endfacet
    outer loop
        vertex +1.0e1 -1.0e1 1.0e1
    endloop
endfacet
    outer loop
        vertex 0.6e1 0.8e1 1.0e1
        vertex +1.6e1 0.8e1 1.0e1
        vertex +0.6e1 1.8e1 1.0e1
    endloop
endfacet
endsolid Simple
3D
As another test, I use the following simple STL file. Just like previous STL, it consists of 5 facets but they are NOT on the same plane. In this case FreeCAD detects the intersection of facet `4` and `1` and deletes it properly.
solid Simple
    outer loop
    endloop
endfacet
    outer loop
    endloop
endfacet
    outer loop
    endloop
endfacet
    outer loop
    endloop
endfacet
    outer loop
        vertex 0.6e1 0.8e1 1.2e1
        vertex +1.6e1 0.8e1 0.0e1
        vertex +0.6e1 1.8e1 0.0e1
    endloop
endfacet
endsolid Simple
Question
The 2D case above is just like the 3D case with some minor differences in `Z` coordinates of some vertices.
I wonder why FreeCAD can detect self-intersection in 3D case? But not in 2D case?
FreeCAD info
Here is the content of `Help > About FreeCAD > "Copy to clipboard"`:
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
jnxd
Re: Self-intersection is not detected when intersecting triangles are on the same plane
Postby jnxd » Mon Aug 30, 2021 3:18 pm
m3g1dd0 wrote: Mon Aug 30, 2021 10:29 am
This is likely happening because of round-off errors while doing floating point operations. Basically the calculations must be giving some very small positive number instead of "<= 0" (around 10^-16 but may be larger depending on number of calculations involved) or something such. I'll take a look when I can.
m3g1dd0
Postby m3g1dd0 » Tue Aug 31, 2021 7:53 am
I have uploaded a FreeCAD project file containing the test cases of 2D and 3D:
https://www.filemail.com/d/urakygvlflcecxq
Note that the link is valid for only 1 week!
jnxd
Postby jnxd » Tue Aug 31, 2021 3:35 pm
PR with fix: https://github.com/FreeCAD/FreeCAD/pull/5002. Note that the mesh somehow disappears now when the check is run, but comes back when "repair" is clicked. This is true for self-intersection and "all of the above" checks. If another test is run before repair, the mesh may not reappear.
chennes
Postby chennes » Tue Aug 31, 2021 7:34 pm
I poked at this weird mesh-hiding thing for a little while today. It seems to occur most often when also checking the normals -- and for me it doesn't happen when running "check all". I can't seem to find a consistent way of reproducing it -- any ideas?
Chris Hennes
Pioneer Library System
jnxd
Postby jnxd » Wed Sep 01, 2021 1:52 am
chennes wrote: Tue Aug 31, 2021 7:34 pm I poked at this weird mesh-hiding thing for a little while today. It seems to occur most often when also checking the normals -- and for me it doesn't happen when running "check all". I can't seem to find a consistent way of reproducing it -- any ideas?
Not sure if I can either. Sometimes i tried it and it didn't hide the mesh. Sometimes I "check all" and everything is hidden :|
chennes
Postby chennes » Wed Sep 01, 2021 4:13 am
Can you get it to happen without your patch? Are we sure it's related?
Chris Hennes
jnxd
Postby jnxd » Wed Sep 01, 2021 6:01 am
chennes wrote: Wed Sep 01, 2021 4:13 am Can you get it to happen without your patch? Are we sure it's related?
Oddly, now I can't even reproduce it with the patch.
chennes
Postby chennes » Wed Sep 01, 2021 12:39 pm
I think this now falls officially into "Heisenbug" territory... :o
Chris Hennes
jnxd
Postby jnxd » Thu Sep 02, 2021 1:26 am
chennes wrote: Wed Sep 01, 2021 12:39 pm I think this now falls officially into "Heisenbug" territory... :o
Yes. Guess we just have to wait and watch. I can't really tell if there are any places where the modified function is used that also changes things.
