Self-intersection is not detected when intersecting triangles are on the same plane
m3g1dd0
Re: Self-intersection is not detected when intersecting triangles are on the same plane
Post by m3g1dd0 »
Thanks guys. I'd like to test the patch, but I guess it requires building and running FreeCAD along with all its dependencies. Is there a quick way to test the patch without setting up FreeCAD build environment? Probably not! I'll test when I have the opportunity... =)
Founder
Post by wmayer »
For coplanar triangles the two intersection points may show garbage values. This means it doesn't just have arbitrary values but some of the coordinates might be NaN.
Now if creating a line and adding it to the scene graph may invalidate the view frustum and this leads to the observed behaviour.
With git commit 8d0d149b5be5d there is now a function to get the intersection points of the edges of triangles.
Founder
Post by wmayer »
The self-intersection function fails again when rotating the mesh with:
from FreeCAD import Base
mat = Base.Matrix()
mat.rotateX(1.0)
mat.rotateY(1.0)
mat.rotateZ(1.0)
mesh = App.ActiveDocument.ActiveObject.Mesh.copy()
mesh.transformGeometry(mat)
App.ActiveDocument.ActiveObject.Mesh = mesh
With git commit 30ba396a82 it works as expected now. The problem was that tri_tri_intersect_with_isectline() doesn't work very reliably for coplanar triangles.
