Offset
JussyAD
Offset
Post by JussyAD »
Any word on the possibility of an all important offset tool for sketcher?
JussyAD
Re: Offset
Post by JussyAD »
and arrays in sketcher?
Re: Offset
There is a macro for offsets.
The array issue was discussed recently quite lengthy. Instead of making sketches more complicated, it is rather advised to use pattern functions.
JussyAD
Re: Offset
Post by JussyAD »
chrisb wrote: Thu Sep 16, 2021 9:53 pm There is a macro for offsets.
Thank you, glad to hear it.
Yes, those functions will suffice!
Cekuhnen
Re: Offset
Post by Cekuhnen »
Yeah I agree - I stay away from sketch patter tools also in my commercial cad apps
They slow the sketches down
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
ideasvacuum
Re: Offset
Post by ideasvacuum »
Tried the Macro in v0.19.2 - fails:
00:34:11 Traceback (most recent call last):
00:34:11 File "C:/Users/Chris_Ward/AppData/Roaming/FreeCAD/Macro/SketcherOffset.FCMacro", line 77, in getPoint
00:34:11 OffsetInSketcher.addOffset(self.SelGeoId,self.OffsetLine)
00:34:11 AttributeError: 'OffsetDialog' object has no attribute 'SelGeoId'
Re: Offset
ideasvacuum wrote: Sun Sep 19, 2021 11:36 pm Tried the Macro in v0.19.2 - fails:
Add your file and describe in detail what you did.
ideasvacuum
Re: Offset
Hi
In the Sketcher
1) Draw a line at a random location/angle/size
2) Select it
3) Apply the Macro - instead of an offset line, an enclosed rectangle is created
4) The rectangle has redundant constraints
5) Report View: Attribute Error
MacroOffsetProblem.FCStd
(4.07 KiB) Downloaded 61 times
Re: Offset
Confirmed. A single line is probably too simple :) .
edi wrote: pinged by pinger macro
OS: macOS 10.16
Version: 0.20.25645 (Git)
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
kisolre
Re: Offset
Post by kisolre »
This is not a rectangle. the extra two lines are construction lines defining the Offset. With other contours they are also generated. The overconstraining is not a problem IMO because it is better to let the solver show the extra constraints and you manually delete them later (usually just two in my tests) than to make the script more cumbersome and trying to solve all corner cases for all geometries.
