FreeCAD will allow me to draw a simple cylindrical object but doesn't create a usable .stl or .dae file for CURA. I've been successfully drawing and printing MUCH more complicated objects with no problems.
I don't understand what the problem is.
Peter
Exporting a simple shape doesn't work
- OldBikerPete
Re: Exporting a simple shape doesn't work
Hi and welcome to the forum!
You have a cyclic dependency in your model: Cylinder is mapped to the Body and Body depends on the cylinder. You should attach the cylinder to XY plane instead.
Cyclic dependencies are shown in red in the report view and with red arrows in the dependency graph.
- OldBikerPete
Thank you chrisb.
That FreeCAD file I included had been hacked around as I tried to get something that worked and did have that circular definition.
However my normal way of working is to use the body for EVERY reference and when I modified that file back to how I originally wrote it - with everything referencing the Body, the circular definition complaint had disappeared and both .stl and .dae files were created.
However that just took me back to the original problem. When CURA read the .stl file, the holes were missing - as I have had with other solids I have drawn, which is why I have used .dae files in the past. When it tried to read the .dae file, it simply produced nothing, no display, no complaint. A repeat attempt just caused it to crash.
Peter.
PS. I should point out that I'm using Windows 7, 64bit.. Windows 10 is just not an option.
Peter.
- Shalmeneser
└ Body (Body)
├ Cylinder000 (Cylinder)
├ Cylinder001 (Cylinder)
├ Cylinder002 (Cylinder)
├ Cylinder003 (Cylinder)
├ Fillet000 (Fillet)
├ Fillet001 (Fillet)
├ Fillet002 (Fillet)
├ Fillet003 (Fillet)
└ Fillet004 (Fillet)
IMHO using PartDesign_Revolution is better :
└ Body (Body)
└ Revolution (Revolution)
└ Sketch (Sketch)
- Capture du 2021-09-19 12-34-58.png (44.52 KiB) Viewed 780 times
- FilamentSpoolAdapter_SHALM.FCStd
- (44.29 KiB) Downloaded 23 times
- OldBikerPete
Thank you for that, I'll give that a try. FreeCAD has SO MANY options, it's a long learning curve.
I'm moving this to the 'Helping with FreeCAD discussion as it evolves into a hand-holding exercise.
