START wb Example Files : PARTDESIGN + TECHDRAW example
Shalmeneser
Post by Shalmeneser »
Use : Pad - Pocket - Revolution - Pipe - Transform - Fillet
└ Body (Body)
    ├ Revolution (Revolution)
    │  └ Sketch (Sketch)
    ├ Pad (Pad)
    │  └ Sketch001 (Sketch)
    ├ Pocket (Pocket)
    │  └ Sketch002 (Sketch)
    ├ Hole (Hole)
    │  └ Sketch003 (Sketch)
    ├ MultiTransform (MultiTransform)
    │  ├ PolarPattern (PolarPattern)
    │  └ Mirrored (Mirrored)
    ├ Pocket001 (Pocket)
    │  └ Sketch004 (Sketch)
    ├ Fillet (Fillet)
    ├ Fillet001 (Fillet)
    └ SubtractivePipe (SubtractivePipe)
       ├ Sketch005 (Sketch)
       └ Sketch006 (Sketch)
edit : new version of Techdraw
Capture du 2021-09-25 23-44-07.png (140.8 KiB) Viewed 1130 times
Capture du 2021-09-26 00-05-13.png (135.93 KiB) Viewed 1110 times
PartDesign_TechDraw_SHALM.FCStd
(135.45 KiB) Downloaded 33 times
chennes
Re: START wb Example Files : PARTDESIGN + TECHDRAW example
Post by chennes »
This is a good model to show off various aspects of Techdraw overall. It is simple enough to understand readily, but complex enough to show important features. That said, I think if the aim is to show off TD here, it would be best to use one of the paper templates: those are a marquee feature of that WB.
Chris Hennes
Pioneer Library System
bernd
Post by bernd »
yeah very good example, not to simple, not to difficault and a cool drawing! Go for a PR to add it!
cadcam
Post by cadcam »
I wonder if example files are to be completed that
at least the drawings are complete to fixed standards
, e.g. BS8888, with typical dimensioning for the item
and features. Also include the ability to show in both
1st and 3rd angle.
Best wishes
