Sketcher Solver Issue
mopy
Post by mopy »
got:
17:46:36 Important: the LevenbergMarquardt solver succeeded where the DogLeg solver had failed.
BT wants only v0.20 based reports, so I'm posting it here, just in case it's of interest.
The Log:
17:46:36  Sketcher::setUpSketch()-T:0
17:46:36  Updating geometry: Error build geometry(0): Both points are equal
17:46:36  Invalid solution from DogLeg solver.
17:46:36  If you see this message please report a way of reproducing this result at
17:46:36  http://www.freecadweb.org/tracker/main_page.php
17:46:36  Sketcher::Solve()-LevenbergMarquardt-T:0
17:46:36  Sketcher::Solve()-LevenbergMarquardt- Failed!! Falling back...
17:46:36  Sketcher::Solve()-BFGS- Failed!! Falling back...
17:46:36  Invalid solution from SQP(augmented system) solver.
17:46:36  Sketcher::Solve()-SQP(augmented system)-T:0.001
17:46:36  Recompute failed! Please check report view.
17:56:02  Save AutoRecovery file: Needed time: 2ms
Reproduce:
App.getDocument('Unnamed').getObject('Sketch').addGeometry(Part.LineSegment(App.Vector(6.299129,8.703989,0),App.Vector(11.474183,5.398911,0)),False)
App.getDocument('Unnamed').getObject('Sketch').addGeometry(Part.LineSegment(App.Vector(8.299570,10.356529,0),App.Vector(15.000000,7.000000,0)),False)
App.getDocument('Unnamed').getObject('Sketch').addConstraint(Sketcher.Constraint('Parallel',0,1))
App.getDocument('Unnamed').getObject('Sketch').addConstraint(Sketcher.Constraint('Parallel',1,-1))
App.getDocument('Unnamed').getObject('Sketch').addConstraint(Sketcher.Constraint('Parallel',0,-2))
Version Info:
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Re: Sketcher Solver Issue
Hi and welcome to the forum!
Thanks for the report, but as far as I can see you have a flaw in your sketch: you seem to have a line of length 0 or a circle with radius 0. You should fix this, because it causes problems in further steps.
For future posts, please put the log outputs in code tags for ease of reading; and add the file showing your issue. It is always appreciated if you simplify such files as far as possible so that they still show the problem, but don't contain any additional stuff.
mopy
Post by mopy »
the log shows the whole sketch. Two lines and three parallel constraints. The line of length 0 is the result of the solver. I stumbled over this, while intentionally creating a constraint conflict.
I'm looking on how to access the SolvedSketch info from Python side.
Regards,
Rolf
Please add your python commands without the leading symbols. You can use "Copy command" in the console.Thus this preparatory step has to be done only once.
mopy
Post by mopy »
Sorry, fixed it.
Can a line of length 0 or a point be parallel to something?
It looks like that one solver thinks it's correct and in turn comes up with a solution that breaks transitivity.
openBrain
Post by openBrain »
mopy wrote: Fri Oct 15, 2021 1:00 pm Sorry, fixed it.
Please tell what you're trying to achieve.
Your constraints (specifically GeoId, PosID) you're using in your Python snippet have strictly no sense. ;)
mopy
Post by mopy »
As I said, while trying to create an invalid constraint (for some testing purpose) I was asked by the code to report an issue. I've just done so.
I did look into the situation a bit. Hence my questions.
IMHO a solver to reduce the length of a line to 0 and thereby breaking transitivity is worth a look.
mopy wrote: Sun Oct 10, 2021 7:25 pm the log shows the whole sketch.
The code given doesn't reproduce a sketch here. It shows a bunch of error messages though. And I think that is correct.
From what I see you try to make things parallel to x- and y-axis at the same time and I am not surprised that things go havoc.
mopy
Post by mopy »
Thx for taking a closer look.
In a more complex scenario it might not be that obvious that this scenario is nonsense.
I would have expected a conflicting constraint message, not a solver goin' crazy.
TestParallelFail.FCStd
(3.95 KiB) Downloaded 43 times
When I open the sketch I see the correct "Both points are equal" message. I wouldn't call that crazy.
