Open Vertices
Open Vertices
Let's say you have 3 Vertices A, B, C where A is coincident constraint to B and B is coincident constraint to C. That should mean that A is also coincident to C.
But that point is still considered an open vertex (sketch.OpenVertices)
I can't make sense of this behavior.
Regards,
Rolf
Regards,
Rolf
Re: Open Vertices
This already has been discussed on another thread.
I think the will behind is to help user discover everything that could be a problem for extruding the sketch, including Y-junctions.
So what is your preferred solution :
* Feature do not report the multiple coincident points ?
* Button is renamed "Find issues" ?
Complaining is fine, proposing is better.
Re: Open Vertices
I found a related issue: Finding missing coincidences shows in the attached sketch 1 open, where 0 would be correct, and 2 would be consistent.
- openVertices.FCStd
- (5.28 KiB) Downloaded 32 times
- ragohix769
Re: Open Vertices
IMHO: feature (or some sanity check for sketcher) should be understand that coincident points are *not* open.
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same
Re: Open Vertices
Coincidence is simply not complete if the vertexes involved are just geometrically equal. While they may physically reside at the same coordinate in 3D space, unless defined as coincident, they aren't. It could be considered a shared property of the vertexes.
In fact, if they are physically co-located, but not marked coincident and they are otherwise constrained, the sketch, assuming no other rule violatons, will pad just fine. But, in this case the solver is not instructed to maintain the coincidence of the vertexes, so chaos may ensue.
Re: Open Vertices
This is correct but the transitivity that A and C are coincident is not explicitly stored in the sketch as otherwise this will raise an error because of redundant constraints.
doc = App.newDocument()
body = doc.addObject("PartDesign::Body", "Body")
sketch = body.newObject('Sketcher::SketchObject','Sketch')
sketch.Support = (doc.getObject('XY_Plane'),[''])
sketch.MapMode = 'FlatFace'
sketch.addGeometry(Part.LineSegment(App.Vector(-55.965607,-9.864289,0),App.Vector(-55.600571,-9.387639,0)),False)
sketch.addGeometry(Part.LineSegment(App.Vector(-55.735817,-9.067246,0),App.Vector(-55.600571,-9.387639,0)),False)
sketch.addConstraint(Sketcher.Constraint('Coincident',1,2,0,2))
sketch.addGeometry(Part.LineSegment(App.Vector(-55.600571,-9.387639,0),App.Vector(-55.058266,-9.677831,0)),False)
sketch.addConstraint(Sketcher.Constraint('Coincident',2,1,0,2))
# This constraint would cause a redundancy
#sketch.addConstraint(Sketcher.Constraint('Coincident',2,1,1,2))
doc.recompute()
The implementation doesn't do what the function name promises:But that point is still considered an open vertex (sketch.OpenVertices)
std::vector<Base::Vector3d> SketchAnalysis::getOpenVertices(void) const
std::vector<Base::Vector3d> points;
TopoDS_Shape shape = sketch->Shape.getValue();
Base::Placement Plm = sketch->Placement.getValue();
Base::Placement invPlm = Plm.inverse();
// build up map vertex->edge
TopTools_IndexedDataMapOfShapeListOfShape vertex2Edge;
TopExp::MapShapesAndAncestors(shape, TopAbs_VERTEX, TopAbs_EDGE, vertex2Edge);
for (int i=1; i<= vertex2Edge.Extent(); ++i) {
const TopTools_ListOfShape& los = vertex2Edge.FindFromIndex(i);
if (los.Extent() != 2) {
const TopoDS_Vertex& vertex = TopoDS::Vertex(vertex2Edge.FindKey(i));
gp_Pnt pnt = BRep_Tool::Pnt(vertex);
Base::Vector3d pos;
invPlm.multVec(Base::Vector3d(pnt.X(), pnt.Y(), pnt.Z()),pos);
points.push_back(pos);
return points;
Re: Open Vertices
Well, the least thing to do - as always. Document the behavior.
You could do something like this to find transitive relations:
cs: Set[Tuple[GeoId, GeoId]]
cn: List[Set[GeoId]] = list()
for x, y in cs:
done = False
for j in cn:
if (x in j) and (y in j):
done = True
break
if (x in j) or (y in j):
j.add(x)
j.add(y)
done = True
break
if not done:
cn.append({x, y})
self._merge_joint_sets(cn)
def _merge_joint_sets(self, cn):
for x in range(len(cn) - 1):
for y in range(x + 1, len(cn)):
if y > len(cn) - 1:
break
if not cn[x].isdisjoint(cn[y]):
cn[x].update(cn[y])
cn.pop(y)
Re: Open Vertices
Actually coincident constraints doesn't come into play here. Specifically, the "Highlight open vertexes" function totally ignores the constraints.
It applies a simple rule that is "Highlight points where not exactly 2 vertices strictly are", which also means :
* It doesn't highlight point pairs having strictly equal coordinates, even if no coincidence is set between both
* It totally ignore the Tolerance value set above (which from UI point of view is a bit weird)
Re: Open Vertices
Here is a slightly modified sketch. It correctly pads perfectly, yet Validate Sketch shows a missing coincidence. It can of course be ignored here, and I prefer to have false positives instead of missed hits, but if there are a lot more of really missing coincidences they can only be fixed automatically when this one is (mal-)fixed too - which then needs editing in sketcher again.
Surprisingly by making the diagonal construction geometry the false Open vertex vanishes.
I think it would at least be worth a feature request, if not a minor bug report.
- (5.25 KiB) Downloaded 37 times
Re: Open Vertices
You probably looked into the implementation? Then it is a precision issue, where equality isn't necessarily transitive.
