benchmarking comparing peformance of freecad mac app bundles
ipatch
Post by ipatch »
i've been trying to keep the homebrew-freecad tap updated, and published a DMG release of mac app bundle ie. a `FreeCAD.app` that should just work by double clicking the app icon after drag n drop to the `/Applications` folder.
i was curious about the load time of a file i've been working with that takes ~ 24 seconds to load on my system using the app bundle i built and published to the github / releases section of the homebrew-freecad tap.
conveniently enough my app bundle appears to be the same build number (commit) as that of the conda weekly release. (how that happened, i have no idea (divine intervention)). either way, the conda release is able to load my file in ~ 20 seconds. not much of a difference to make a deal breaker. but curious enough (wish i could insert cat emoji without blowing up the browser rendering(phpbb you suck)).
...is there a way to test / analyze / benchmark freecad, ie. like see what it is that is taking the bulk of the time to load the file?
and i am aware of the `freecad -t 0` command but am wondering if there any other way to analyze / "instrument" the build to see what could possibly be slowing things down.
TheMarkster
Re: benchmarking comparing peformance of freecad mac app bundles
Post by TheMarkster »
ipatch wrote: Sat Oct 23, 2021 4:45 pm ...is there a way to test / analyze / benchmark freecad, ie. like see what it is that is taking the bulk of the time to load the file?
There is a macro for profiling how long it takes to recompute the document. It show the recompute time for each object that was recomputed.
It's called Recompute Profiler
Usage: Run the macro the first time to block recomputes from happening. Change some property of each object to be recomputed. Run the macro again. Check the report view for results.
jonasb
Post by jonasb »
My poor-man's approach is usually: Send an object to the python console (from the context menu in the tree) and then
from time import perf_counter
start = perf_counter(); obj.recompute(); perf_counter() - start
But it gives you only end-to-end durations; so not the kind of profiling info you asked for
