[SOLVED]Basic Python question - Related to my WB -last bug fix
mariwan
Post by mariwan »
can anyone explain why this was failing?
def getDirectionAxis(s=Gui.Selection.getSelectionEx()):
"s" couldn't get the selection. It was empty
I needed to take it back to how it was . i.e.
def getDirectionAxis(s=None):
Thanks in advance
jonasb
Re: Basic Python question - Related to my WB -last bug fix
Post by jonasb »
https://docs.python-guide.org/writing/gotchas/ wrote:Python's default arguments are evaluated once when the function is defined, not each time the function is called (like it is in say, Ruby).
mariwan
Post by mariwan »
jonasb wrote: Sat Oct 23, 2021 8:37 pm
Thank you very much Jonasb.
Correct, that must be the reason ... But it is not logical. I call that as a bug in python.
Anyway, I did what is required even if I didn't know that. I am new in python.
Thank you again.
TheMarkster
Post by TheMarkster »
mariwan wrote: Sun Oct 24, 2021 9:56 am
Thank you again.
I would argue it's not a bug in python *if* it results in faster execution.
