Playing around with freecad, and found something that seems just-not-right; since the bug-tracker
seems to encourage posting here first, here I am....
I have a sketch (attached), shows as fully constrained, but when I change a dimension, it will often get into a state
where it complains about "Conflicting constraints, remove ##", change it back to the original value, and it
still complains.
CTRL-Z twice, back to the original state (solver is not showing an error message), make a smaller change
and it will be ok. Change it again to the value that first caused the problem, and it's still ok.
For example, starting with the 13mm constraint, change it to 14 and there's a problem. Back to 13 and the
problem persists. CTRL-Z twice back to 13 (ok), change to 13.5, ok, change to 14, ok.
Problem is present on changes to any of the linear dimensions (didn't try the radial ones)
Not sure if I should bug-report this, if it's a known issue, or if more details (beyond the usual FC version and OS info)
are needed.
It actually took several attempts to create the sketch without it getting in to this sort of instability in the
first place. Often I would be attempting to sketch the inner wall, and after adding a constraint that did not
overconstrain the drawing, the solver would start complaining, but about constraints not related to the one
just added.
-- James
