Zoom Actual PR (poll)
Re: Zoom Actual PR (poll)
wmayer has also found another issue when the camera is not orthogonal, but perspective, where the height attribute is unavailable. Perspective might not even have been an option at the time the macro was written.
Edit: It does have a scaleHeight() function, but with just a bit of expermentation it appears only to scale whatever the current camera height happens to be. For example, scaleHeight(1) does nothing, but scaleHeight(2) would zoom out. I haven't used this camera mode much because I never liked it. This sort of scaling might not even make sense for this camera mode. If that's the case, then the thing to do would be to check in isActive() and return False unless in ortho mode.
No it doesn't because perspective projections don't keep dimensions. If you rotate the above mentioned cube then you can see that the edge lengths will change without changing the height angle of the camera.TheMarkster wrote: ↑Thu Oct 28, 2021 5:04 pm This sort of scaling might not even make sense for this camera mode.
Either this or you pop up a dialog in the activated() method that the function cannot be used for non-orthographic cameras. I prefer the latter because ofr many users it isn't very obvious what needs to be done to make the command to become active.If that's the case, then the thing to do would be to check in isActive() and return False unless in ortho mode.
Yes, this is better. I'll add it to the PR.
- adrianinsaval
maybe a warning in the report view is better than a popup as it's less invasive but I think it would still catch the attention of most
I am not a fan of showing such messages (only) in the report view. Instead of popping up a modal dialog an alternative could be to tmp. show a message in the 3d view. In FreeCAD we have the class StatusWidget for this kind of purposes that can be combined with a timer and shown for a few seconds.
But I still wonder in which cases the function apparently doesn't work and when this tweak factor is needed. Could this be related to HiDPI monitors?
I just compiled and tested.
I have a ASUS MG28U 4K monitor.
The result of the "Zoom Actual" command depends on my Plasma desktop "Global Scaling" factor.
For a 100mm cube, here are my results :
- Global Scaling = 100x, cube measure = 100mm ... Working
- Global Scaling = 150x, cube measure = 66mm ... Fail
- Global Scaling = 200x, cube measure = 50mm ... Fail
And my FC info :
And my FC info :
OS: Manjaro Linux (KDE/plasma)
Version: 0.20.26244 +4 (Git)
Branch: zoom
Hash: 26f2eabd4a5e9c69d29957dca434a34bd8852332
Python version: 3.9.7
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: French/France (fr_FR)
- adrianinsaval
That's some weird behaviour by Qt, physicaldpi is meant to be independent of scaling factors precisely
On a normal monitor it's possible to test a few HiDPI things by setting QT_SCALE_FACTOR. When I set it to 2.0 and run the macro the object is clearly too small -- by the same factor.
So, obviously HiDPI matters and must be respected to get the correct scaling. For this we have the method QWidget::devicePixelRatioF()
Would using logicalDpiX instead of physicalDpiX help?
Can't test right now by myself.
It works here on Debian with a 4K Monitor. But i do not like the feature, because it is too fault-prone an can ruin to monitor. I think this is maybe the main reason, why other CADs do have that function. But i am not strictly against it, if someone want to ruin the monitor.
Greetings
user1234
Greetings
user1234
