Sketcher: drive the intent in slot creation
Piero69
Post by Piero69 »
currently the slot creation in sketcher is free and you have to constrain it after. i feel very useful to have at least working horizontal and vertical constraints during the creation to drive the intent. i mean something like that:
1) click the first point
2) ability to use H or V constraint by keyboard
3) click the second point (constrained according to H or V selection)
if you skip the "step 2" the slot is free like now
what do you think?
Re: Sketcher: drive the intent in slot creation
It used to be horizontal and vertical only. It may be helpful to do something similar to the Ctrl-key with the Polyline tool: If the Ctrl key is pressed, then the old vertical/horizontal constraints are applied.
openBrain
Post by openBrain »
Something like this ?
Concerning one of your last PRs: Obviously it is not only crash fixes, that can be implemented extremely fast :D .
openBrain
Post by openBrain »
chrisb wrote: Thu Nov 25, 2021 10:44 am Concerning one of your last PRs: Obviously it is not only crash fixes, that can be implemented extremely fast :D .
:lol: If you look at the code of the PR, you can see it's not such a big deal. ;) And my own opinion is that this feature is interesting, which also counts. :)
FYI, I choosed the Ctrl key before you said it to be in sync with the 45° snapping feature of polyline arcs. ;)
openBrain wrote: Thu Nov 25, 2021 10:47 am FYI, I choosed the Ctrl key before you said it to be in sync with the 45° snapping feature of polyline arcs. ;)
Let's take this as a proof that it is sensible to have things consistent. :D
drmacro
Post by drmacro »
FWIW
The arcslot and roundedrectangle macros here result in constrained shapes that can be moved or rotated.
https://github.com/macdroid53/FreeCADScripts
freedman
Post by freedman »
Could it be smart? If you drag H or V then it constrains H or V, if other then it is free. This would be tablet friendly. This probably won't be as easy but it could be the start of adding new options without key strokes.
openBrain
Post by openBrain »
freedman wrote: Thu Nov 25, 2021 4:23 pm Could it be smart? If you drag H or V then it constrains H or V, if other then it is free. This would be tablet friendly. This probably won't be as easy but it could be the start of adding new options without key strokes.
That would be pretty easy to implement actually.
