Thickness problem
Thickness problem
OS: Windows 10 Version 2009
Version: 2021.1015.24301 +4280 (Git)
Branch: LinkDaily
Hash: 556c87868ea46796242156e9f73eae98259794b7
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
The freecad thickness command does not work properly.
Make thickness inwards side is not work properly. Works well on the outside but inner side is not work properly
Branch: LinkDaily
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- 123.zip
- (139 KiB) Downloaded 30 times
- 3.jpg (148.87 KiB) Viewed 2236 times
- 2.jpg (461.07 KiB) Viewed 2236 times
- 1.jpg (114.3 KiB) Viewed 2236 times
Re: Thickness problem
Yes
To explain this rather short answer: there were several thickness related posts today where such issues are explained. It boils down to: Yes, there are these issues. And more cannot be said.
Couldn't resist . You have to model the material you want to take away using other subtractive features.
It is a well known issue. It is from the 3D engine that FreeCAD uses (OpenCascade OCCT).
FreeCAD has little or no influence on the development or improvement of OCCT.
In the mean time most of us have learned how to do such things without the Thickness tool. Like pocketing out the insides.
