Sketcher: oblique rectangle and parallelogram tool
Piero69
Post by Piero69 »
i feel useful that also the rectangle tool is driven by "ctrl key" to choose horizontal/vertical or oblique creation just like the forthcoming
implemention in slot tool.
Also, in sketcher is missing a tool to make a generic parallelogram
i know both them could be workarounded (moro or less) by a polyline but a direct command is doubtless better
openBrain
Re: Sketcher: oblique rectangle and parallelogram tool
Post by openBrain »
Piero69 wrote: Thu Dec 02, 2021 8:17 am i feel useful that also the rectangle tool is driven by "ctrl key" to choose horizontal/vertical or oblique creation just like the forthcoming
This would need rectangle to be drawn with perpendicular constraints instead of direct horizontal/vertical ones, which is a bit less solver efficient.
Given that, should we move to this for all rectangle, or add oblique rectangle as a variant ?
Shalmeneser
Post by Shalmeneser »
Sketcher_CreateRectangle + Sketcher_RemoveAxesAlignment = oblique rectangle
Parallelogram : never used
Piero69
Post by Piero69 »
oblique rectangle as a variant is the best solution i think
openBrain wrote: Thu Dec 02, 2021 9:57 am
Piero69
Post by Piero69 »
yes i know, but it's more long... three steps for an intent
1) sketch a rectangle
2) remove aligment
3) insert an angular constraint
with oblique rectangle as variant in the tool you sketch and then dimension the angle saving one step
Shalmeneser wrote: Thu Dec 02, 2021 11:14 am Sketcher_CreateRectangle + Sketcher_RemoveAxesAlignment = oblique rectangle
drmacro
Post by drmacro »
Piero69 wrote: Thu Dec 02, 2021 1:49 pm ...saving one step
So, you save what? 100 milliseconds? :roll:
Sorry, I just don't get the need for such savings. :?
Yes, I get it, I'm just an old crank and humbug. :mrgreen:
I too am against such tools for rather special use cases. Furthermore there is a tool to remove the axis alignment.
obelisk79
Post by obelisk79 »
Seems like a parallelogram is a bit of a fringe requirement to be added as a tool. Perhaps you could write a simple macro function to do this, and share with the community, rather than it be added as a permanent function.
