[SOLVED]Solid created by shell-faces-tollerance-sew has problem. Sew or Tollerance dosen't create solid?
mariwan
Post by mariwan »
My EdgeExtend supposed to create solid .. my code should create a solid but when I try with python to check it if it is solid .. it fails.
I upload the file and the picture of the code I used. And I checked even with defeaturing geometry check ...it should be ok. but it isn't.
bug in Part WB? or what?
what you see in the left is the answer of the defeaturing WB - geometry check. and in the right is the code i used to check but it says "Shell"
thanks in advance.
test.FCStd
(5.31 KiB) Downloaded 11 times
openBrain
Re: Would you please let me know why it is wrong?
Post by openBrain »
Can confirm your object is a shell. Just "drill" it by cutting a box or cylinder and you'll see. ;)
Maybe it comes from the way you create it, but hard to say without any more clue.
mariwan
Post by mariwan »
openBrain wrote: Thu Dec 02, 2021 4:50 pm Can confirm your object is a shell. Just "drill" it by cutting a box or cylinder and you'll see. ;)
            soldObjShape = _part.Solid(_part.Shell(_resultFace))
            newObj = App.ActiveDocument.addObject("Part::Feature","comp")
            newObj.Shape = soldObjShape
            newObj = self.sewShape(newObj)
            newObj = self.setTolerance(newObj)
            for face in self.newFaces:
                App.ActiveDocument.removeObject(face.Name)
that is the code. I use Part.Solid.. Shouldn't that create a solid? I took it from the FreeCAD wiki
openBrain
Post by openBrain »
mariwan wrote: Thu Dec 02, 2021 4:53 pm that is the code. I use Part.Solid.. Shouldn't that create a solid? I took it from the FreeCAD wiki
Those 2 lines don't make much sense ATM as they are redefining your 'newObj' variable with some functions that I don't see (don't know type of 'self' and if functions are native or custom).
Anyway if I do in your example file
Part.show(Part.Solid(App.ActiveDocument.Solid.Shape))
everything is fine and I get a solid. So I think the problem isn't in FreeCAD. ;)
BTW : Defeaturing tells you "Solid" because it is the name of the object, not because it is an actual solid. ;)
mariwan
Post by mariwan »
def setTolerance(self, sel):
        try:
            if hasattr(sel, 'Shape'):
                ns = sel.Shape.copy()
                new_tol = 0.001
                ns.fixTolerance(new_tol)
                sel.ViewObject.Visibility = False
                sl = App.ActiveDocument.addObject("Part::Feature", "Solid")
                sl.Shape = ns
                g = Gui.ActiveDocument.getObject(sel.Name)
                g.ShapeColor =   sel.ViewObject.ShapeColor
                g.LineColor =    sel.ViewObject.LineColor
                g.PointColor =   sel.ViewObject.PointColor
                g.DiffuseColor = sel.ViewObject.DiffuseColor
                g.Transparency = sel.ViewObject.Transparency
                App.ActiveDocument.removeObject(sel.Name)
                sl.Label = 'Extended'
                return sel
        except Exception as err:
            App.Console.PrintError("'sewShape' Failed. "
                                   "{err}\n".format(err=str(err)))
            exc_type, exc_obj, exc_tb = sys.exc_info()
            fname = os.path.split(exc_tb.tb_frame.f_code.co_filename)[1]
            print(exc_type, fname, exc_tb.tb_lineno)
    # Based on the sewShape from De-featuring WB,
    # but simplified- Thanks for the author
    def sewShape(self, sel):
        """[Fix issues might be in the created object]
        Args:
            sel ([3D Object]): [Final object that needs repair.
                                Always new object creates as result of sew]
        try:
                sh = sel.Shape.copy()
                sh.sewShape()
                sl = App.ActiveDocument.addObject("Part::Feature", "compSolid")
                sl.Shape = sh
                g = Gui.ActiveDocument.getObject(sl.Name)
                g.ShapeColor = Gui.ActiveDocument.getObject(sel.Name).ShapeColor
                g.LineColor =  Gui.ActiveDocument.getObject(sel.Name).LineColor
                g.PointColor = Gui.ActiveDocument.getObject(sel.Name).PointColor
                g.DiffuseColor = Gui.ActiveDocument.getObject(
                    sel.Name).DiffuseColor
                g.Transparency = Gui.ActiveDocument.getObject(
                    sel.Name).Transparency
                return (sl)
These are faces that I convert them to shell -->solid --> fix tollerance --> sew
I tested in Part WB the tool - >Make Solid .. it convert it to solid .. but I do the same sequence that tool tells me.
openBrain
Post by openBrain »
IMO, setTolerance returns 'sel' instead of 'sl'.
Shalmeneser
Post by Shalmeneser »
Could you choose more specific title for your post, please ?
mariwan
Post by mariwan »
openBrain wrote: Thu Dec 02, 2021 5:16 pm IMO, setTolerance returns 'sel' instead of 'sl'.
:oops:
Yes you are right.
But for fixing the solid problem .. I needed to recreate a solid object again. Seems that sew or tolerance shapes are not solid. Regarding the Defeature.. I was not clear but I used the checking function for solid .. so it was telling me that it was ok .. you can try it.
Here my final code which works.
    def recreateObject(self):
        # FIXME:
        # Here we have
        # We try to create a wire-closed to replace the sides we delete.
        # This will be way to complex . with many bugs :(
        try:
            App.ActiveDocument.removeObject(self.newEdge.Name)
            _result = []
            _resultFace=[]
            _result.clear()
            for faceVert in self.savedVertices:
                convert = []
                for vert in faceVert:
                    convert.append(vert.Point)
                _Newvertices = convert
                newPolygon = _part.makePolygon(_Newvertices, True)
                convert.clear()
                newFace = _part.makeFilledFace(newPolygon.Edges)
                if newFace.isNull():
                    raise RuntimeError('Failed to create face')
                nFace = App.ActiveDocument.addObject("Part::Feature", "nFace")
                nFace.Shape = newFace
                _result.append(nFace)
                _resultFace.append(newFace)
            self.newFaces = _result
            solidObjShape = _part.Solid(_part.Shell(_resultFace))
            newObj = App.ActiveDocument.addObject("Part::Feature", "comp")
            newObj.Shape = solidObjShape
            solidObjShape = _part.Solid(newObj.Shape)
            final = App.ActiveDocument.addObject("Part::Feature", "Extended")
            final.Shape = solidObjShape
            App.ActiveDocument.removeObject(newObj.Name)
            App.Console.PrintError("'recreate Object' Failed. "
thank you for pointing out the problem.
Note:
Unfortunately, Part.Show doesn't return the created object. Which is a big problem .. You cannot use it in python. How can you find the created object? it is impossible if you think general.
mariwan
Post by mariwan »
Shalmeneser wrote: Thu Dec 02, 2021 5:35 pm Could you choose more specific title for your post, please ?
sorry, you see it became a long title.
Shalmeneser
mariwan wrote: Thu Dec 02, 2021 6:11 pm sorry, you see it became a long title.
No problem. It will be better for memory and future research.
