Bug or cluelessness ?
Ank
Post by Ank »
I am running the weekly FreeCAD_0.19-24291-Linux-Conda_glibc2.12-x86_64.AppImage because the current release does not run on current Ubuntu with i9 Intel graphics.
The first sketch on XY was fine, but I am unable to place another sketch on YZ without some odd degrees.. please see screenshot.
(the angles in "base" section are not editable)
Is this a bug - or something I miss competely?
Screenshot from 2021-12-06 11-39-18.png (79.38 KiB) Viewed 994 times
-alex-
Re: Bug or cluelessness ?
Post by -alex- »
Could you elaborate a bit more, or send the file?
What's the "faulty" sketch? Sketch001 or Scketch002?
Ank
Post by Ank »
Both 001 and 002 (when made on YZ plane, spawn with those odd angles.)
The padded sketch is on "XY_Plane" - and is normal:
Screenshot from 2021-12-06 12-40-11.png (31.78 KiB) Viewed 937 times
Any new sketch I tried to add, has the odd angles... (as seen in the first post).
The same goes for any sketch I create when a face is selected (see below:)
Screenshot from 2021-12-06 12-43-22.png (26.76 KiB) Viewed 935 times
Ank
Post by Ank »
Sorry - my bad, the first sketch makes a skewed object, then I got confused by the odd angles.
It works fine after all.
