This is how I understand it: FreeCAD uses icons from the system theme when they are available by default, naturally common operations that are found in other softwares are in the system theme (open, copy, undo, view fit, etc) but FreeCAD specific stuff is not in those themes (create Part, Front View, etc) so the FreeCAD provided icons are used. When you set that parameter, the system theme folders are removed from the icon search path and only the FreeCAD provided icons are available to the program.
IIRC yorik had made the change to make FreeCAD use the system icons or maybe this was always the case, I don't know for sure. A few years ago triplus created that parameter to remove the system paths, this was discussed here: https://forum.freecadweb.org/viewtopic. ... 10#p365998
I don't know if it's possible to keep the system icons available and give the FreeCAD icons priority but IMO this would be a better behavior. Yorik and others said using the system icons is a better default behavior in Linux but given that the view fit icons will most likely not be appropriate maybe this isn't true for FreeCAD
Missing 2 ViewFit icons in toolbar
- adrianinsaval
Re: Missing 2 ViewFit icons in toolbar
TIL. Thanks!
That makes sense to me. But not sure what the technical implications are to that.adrianinsaval wrote: ↑Wed Jan 12, 2022 9:53 pm I don't know if it's possible to keep the system icons available and give the FreeCAD icons priority but IMO this would be a better behavior.
I've been using FC for 10 years. First time I see these icons
Thanks a lot !
That killed meadrianinsaval wrote: ↑Wed Jan 12, 2022 9:53 pm I've been using FC for 10 years. First time I see these icons
Thanks a lot
I keep thinking about this issue. This is utterly confusing to newbs. Especially such an important function like ViewFit for a beginner not to know!
So I'm wondering if there is a way for FC to have logic to test if it's on a system that is missing the icons for this functionality?
- adrianinsaval
If the icons are missing in the system theme then FreeCAD's icons would be used. The system icon's are just too different to FreeCAD's and that is confusing you.Kunda1 wrote: ↑Sat Feb 05, 2022 10:23 pm I keep thinking about this issue. This is utterly confusing to newbs. Especially such an important function like ViewFit for a beginner not to know!
