Freecad 2D brep files failed to show up in gmsh (solved)
Gary R
Post by Gary R »
I have been trying to model the flow in a piping system. I created a sketch in freecad and have tried several approaches to creating a 2D surface and then exporting the results as a .brep file to gmsh. The files do not show up on the gmsh GUI. I have tried to use the surface workbench and the part workbench to create a surface. Neither seem to work. Attached is the freecad file for the project.
Thanks for you reply
Gary R
PointContact.FCStd
(14.02 KiB) Downloaded 28 times
Re: Freecad 2D brep files failed to show up in gmsh
I'm not at all sure about this, but doesn't it need something 3dimensional to model airflow?
KAKM
Post by KAKM »
chrisb wrote: Mon Jan 17, 2022 11:05 pm I'm not at all sure about this, but doesn't it need something 3dimensional to model airflow?
It depends on what you're trying to model. You don't need a 3D model unless you're trying to capture a 3D phenomena (e.g., turbulence). It's pretty common to use a two-dimensional model to get a general sense of what the system is doing (pressures, velocities, etc.) since it computes so much faster, and then go to three dimensions as needed for additional information.
Thanks for the info! Should I move this to the FEM forum?
Gary R
Post by Gary R »
KAKM is correct . I use 2D for all kinds of symmetric models but have a chronic problem of things not showing up in gmsh. I know that I am doing something fundamentally wrong but what?
Gary R
KAKM
Post by KAKM »
Figured it out. I think you had the body selected when you clicked export–that yields an empty file. If you select the three surfaces of interest, then click export, the resultant file is (I think) what you wanted. It opened in gmsh just fine for me.
chrisb wrote: Mon Jan 17, 2022 11:46 pm Should I move this to the FEM forum?
It might be easier to find there for someone with a similar question later. Or it might not be.
user1234
Post by user1234 »
Important for that are the FreeCAD infos (see red banner above), the VTK version and the report output.
Just said: atm FEM with gnsh have issues with VTK > 7 .
Greetings
user1234
edit: minor typo
Moved.
Gary R
Re: Freecad 2D brep files failed to show up in gmsh {solved}
Post by Gary R »
My sketch essentially contains 3 parts. If I use the surface workbench on each part separately and then highlite all 3 surfaces to export, gmsh works fine.
I included the new file.
Gary R
PointContact.FCStd
(13.54 KiB) Downloaded 20 times
user1234
Re: Freecad 2D brep files failed to show up in gmsh (solved)
Post by user1234 »
So, now i can test files. For me all files meshes fine. But i get on the newer file errors in the sketch. This is probably because you use an older (or other) version of FreeCAD (i do not know, since i have no infos). But as long it works for you.
testet with:
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.20.27089 (Git)
Hash: ead1bce8e994358388fd6dd993f0c9b756ec0eac
Python version: 3.9.2
Qt version: 5.15.2
OCC version: 7.6.0
with:
gmsh 4.9.0
VTK 7.1.1
Greetings
user1234
