[Design] Drawing a wire (inductor) on shapes
mcgiwer
Re: [Design] Drawing a wire (inductor) on shapes
Post by mcgiwer »
I was able to download the both files provideds in this topic ;-)
TheMarkster
Post by TheMarkster »
chrisb wrote: Wed Jan 19, 2022 10:31 am Such parameters could do the trick:
Here is the same formula using Parametric Curve FP macro.
Snip macro screenshot-a808d6.png (80.33 KiB) Viewed 1324 times
And the JSON text version:
{"formula": {"a": "6", "b": "1", "c": "20", "d": [], "X": "(a + b * cos(c*t))*cos(t)", "Y": "(a + b * cos(c*t))*sin(t)", "Z": "b*sin(c*t)", "t": "0.0", "t_max": "6.283185307179586", "interval": "0.02"}}
To import the JSON, in the File property browse to the above text saved into a file, such as json.txt. Then toggle Read File to True to read it into the set of formulas.
coil.parametric_curve_fp.FCStd
(24.68 KiB) Downloaded 17 times
mcgiwer
Post by mcgiwer »
That looks great as well. And what in case if I would like to do the coils more tight:
--|^v^v^|--
or do coil modules:
--|^v-^-v-^-v|---|^-v-^-v-^-v|----|^-v-^-v-^-v|--
or
--|^v^v^|----|^v^v^|--
TheMarkster
Experiment with different values for a, b, and c.
And max(t) if you want segments only.
mcgiwer
Post by mcgiwer »
Thanks all for the help. I appreciate it much :-)
I'll check it all whenever the addon download start to work for me. In the mean time, if there are any more ideas then I'm sure I'll check them when I get able to :-)
onekk
Post by onekk »
mcgiwer wrote: Wed Jan 19, 2022 3:22 pm Thanks. I'll try it out whenever I get able to download the macros's and plugins... for now I get an strange error about beeing unable to connect to wiki to download it (reported as an bug)
Probably the bug is related to the way proxy are set, I've noted that in Preferences >> "Addon Manager" the Proxy is set to "custom", I've to set it to "no proxy" (as I've no proxy) to make it work with a stock AppImage on Linux.
Try to see if this is not also you problem.
Regards
Carlo D.
- Various other stuffs.
mcgiwer
Post by mcgiwer »
@onekk
Thanks for the suggestion, but I have the proxy disabled in FreeCAD from the begining, so that's not a issue reason
