Extension of about freecad?
- thomas-neemann
there seem to be more questions related to the graphics card. does it make sense to eject the graphics card with about freecad? or does it make sense in the forums to give recommendations to indicate it in the questions? for ubuntu you can do it e.g. with lspci -nnk | grep -i display VGA -A2.
linux has e.g. independent of freecad problems with nvidia. this could also be referred to at the appropriate point
Re: Extension of about freecad?
When I extended infos with DE+WM, I had a look at it but found no cross platform way to get sensible info about GFX setup. Moreover it would need to know both chipset and driver. And requiring any user requiring help to manually find this seems boring to me.
- thomas-neemann
ok, It's a shame that there isn't a cross-platform solution. one could adapt the recommendation that the graphics card is given in the event of display problems, most users know that, that should be easy
Sadly there is no common platform solution, and not even an unique solution, maybe something related to Xorg have been a viable way, but now there is also wayland, so there is no a "standard way" to do things, even in Linux.
It will be interesting, but, you have to code at least three ways, one for each OS used, maybe two for Linux if you won't rely solely on Kernel output, that could be seen as a decent way, but in a multiple card installation, or more simple in computers with internal graphics and discrete Graphics board it is difficult to say what is used at runtime, as there are two graphics hardware.
Not talking about some dedicated graphics stations with multiple cards and maybe multiple "computing co processor card" like in some high end installation".
Regards
Carlo D.
Regards
Carlo D.
- Various other stuffs.
- thomas-neemann
thanks for the good information
Maybe related?
https://doc.qt.io/qt-6/topics-graphics.html
maybe Qt itself could give some informations about platform hardware, i has to know how to use and manage things, as the image seems to suggest.
EDIT: After some research it seems that Qt is not able to get such info, but maybe some other OpenGl library in FreeCAD could do as OpenGl has to know on which hardware is running.
Regards
Carlo D.
- thomas-neemann
is there information about whether there is tested hardware for qt? I think this is transferrable to freecad
Sadly most of this post are not solving problems, maybe introducing new one, it may be totally useless, have mercythomas-neemann wrote: ↑Sun Jan 23, 2022 12:36 pmis there information about whether there is tested hardware for qt? I think this is transferrable to freecad
In the linked page there is:
The supported graphics APIs are:
OpenGL (version 3 and higher)
OpenGL ES (version 2 and higher)
Vulkan (1.0 and higher)
Direct3D 11 (11.1 and higher)
Metal
I think that you have to think these sort of thing, like an onion, FreeCAD is the outer slice, Qt is the one slice down, and the graphics API are another slice down.
As (OpenGl is and OpenGL ES and Vulkan) usually are for Linux, (OpenGl, OpenGL ES and Direct3D) should be for Windows.
Some not to deep investigations should shown which API is used on each Platform, in an Expanded AppImage, not very recent of the 0.20 branch I have:
../FreeCAD/squashfs-root/usr/lib/libGLEW.so.2.1.0
../FreeCAD/squashfs-root/usr/lib/libGLU.so.1.3.1
https://wiki.archlinux.org/title/OpenGL
It sems that actualy FreeCAD is using the SoQt interface between Coin3D and Qt so it is the "old" way, new is Quarter.
So the problems could be a different levels.
In the Help part of the forum there are some post that evidentiate that Main interface is working while 3D View (managed by Coin3D) is not, so mileage may vary.
I doubt now after some investigations that Qt will supply relevant information about the potential problems with rendering.
Maybe if some developers will make some light it will be a good thing, or RealThunder, as it is trying to make a different Renderer for his branch, so he may have more in deep knowledge of the "complicated paths" between FreeCAD and the GPU.
Regards
Carlo D.
- thomas-neemann
hello carlo
thanks for the cooperation. Does it make sense to create a thread that is pinned, where users report on well-functioning hardware-software combinations, so that there is orientation?
thomas
I personally think that it would add not needed complexity.
When it is needed and GPU is suspected, it is a simple thing to ask a question?
Benefit of automating this process is doubtful, implementation cost (time and effort) is high and alternatives are simple and easy to use
Developers time is better used improving FreeCAD ....
