Ticket #6266: recompute undos removeSplitter
Post by Kunda1 »
issue #6266: recompute undos removeSplitter
When calling `move`, the object moves, then I call `obj.Shape.removeSplitter()` and `doc.recompute` and the shifted box is unmoved.
Execute the following in the Python console:
from freecad import app as FreeCAD
import Draft
doc = FreeCAD.newDocument("testDoc")
box1 = doc.addObject("Part::Box", "Box1")
doc.recompute()
box2 = Draft.move(box1, FreeCAD.Vector(1, 0, 0), copy=True)
box2.Shape = box2.Shape.removeSplitter()
doc.recompute()
Reason: Added GH ticket number to thread title
Re: Ticket #4754: recompute undos removeSplitter
Post by Kunda1 »
@openbrain responds
openbrain wrote: the problem is that you're not authorized to override a Shape property. You should use a new object.
I tested and there seems to me that there are 2 problem though : 1) the rendered shape is temporarily overridden (before change is rejected) + 2) trying to assign a new shape resets the Placement property -- this is what you see --
openBrain
Post by openBrain »
Kunda1 wrote: Mon Jan 24, 2022 8:17 pm @openbrain responds
Are you expecting something specific from this thread ?
Post by Kunda1 »
was just making it more convenient to read ;)
adrianinsaval
Post by adrianinsaval »
I think this is expected behavior so it should probably be closed. When performing such operations on the shape it's unreasonable to expect them to remain after a recompute, recompute recreates the shape using the feature's method with the properties of the object, it cannot know what additional operations the user performed directly on the shape through the python interface. As was said in the tracker if the user wants to keep the modified shape he needs to create a new object to store it.
A feature request could be made for a parametric refine but that should probably be done in a new well written ticket if it doesn't exist already.
Edit: ignore, i missinterpreted the issue as the refniment being lost after recompute but this was not the case at all. regarding a parametric refine feature, it's likely not necessary because AFAIK most parametric features have the refine property to do this
Last edited by adrianinsaval on Tue Jan 25, 2022 6:31 pm, edited 2 times in total.
Post by Kunda1 »
adrianinsaval wrote: Tue Jan 25, 2022 5:50 pm A feature request could be made for a parametric refine but that should probably be done in a new well written ticket if it doesn't exist already.
Care to make a new one while I close this one? :D
adrianinsaval
Kunda1 wrote: Tue Jan 25, 2022 5:52 pm Care to make a new one while I close this one? :D
sorry completely missinterpreted the issue, please don't close yet
adrianinsaval
Two possible issues I see after having a deeper look into it:
1- attempting to change the shape of the box (with whatever shape, removeSplitter is unrelated) resets the placement of the box. I do not know why, I understand it's not allowed to change the shape however IMO it shouldn't change the placement of the object.
2- calling for example the built-in scaled function directly on box1.Shape results in the following error:
>>> box1.Shape.scaled(5)
ReferenceError: This object is immutable, you can not set any attribute or call a non const method
but calling box1.Shape.removeSplitter() is allowed, can anybody explain the rationale here?
openBrain
Post by openBrain »
adrianinsaval wrote: Tue Jan 25, 2022 6:29 pm Two possible issues I see after having a deeper look into it:
1 is a problem. Not a major one, but can be improved though.
2 is expected (actually, this is even how 1 should behave). You have to call box1.Shape.copy().scaled(5)
adrianinsaval
openBrain wrote: Tue Jan 25, 2022 6:49 pm 2 is expected (actually, this is even how 1 should behave). You have to call box1.Shape.copy().scaled(5)
but why is removeSplitter() allowed without using copy()?
