FreeCAD slower startup
openBrain
Re: FreeCAD slower startup
Post by openBrain »
chennes wrote: Wed Jan 26, 2022 7:18 pm Better odds that it's my fault -- I wonder if it's the initialization process of the QNetworkAccessManager used by the Addon Manager. Let me poke at it.
ETA: That's git commit 2b0a4dc64339266b2e0b45fb974f9ab105fde1ae if someone else wants to look. The QNAM runs on its own thread, so I don't think it should block startup, but maybe I've screwed something up.
Can confirm that this commit is creating both loading slowness and CPU 100% usage on one core. Looks like at some time it's blocked on a network call or whatever.
Will try to test fix commit.
user1234
Post by user1234 »
chennes wrote: Thu Jan 27, 2022 12:44 am When you have a moment, can you please test git commit f045a0b6f12ec82c0ddb44570c81dfcc3940af0d?
Yes, this commit starts normal. Thanks!
Greetings
user1234
openBrain
Post by openBrain »
user1234 wrote: Thu Jan 27, 2022 12:12 pm Yes, this commit starts normal. Thanks!
Does it still use 100% CPU core on idle when running ?
chennes
Post by chennes »
openBrain wrote: Thu Jan 27, 2022 1:41 pm Does it still use 100% CPU core on idle when running ?
That commit probably does -- that was the "emergency" part of the fix. The rest of the refactor took a little longer, but I pushed it last night, in git commit bfada57b0. That should eliminate the extra CPU usage.
Chris Hennes
Pioneer Library System
openBrain
Post by openBrain »
chennes wrote: Thu Jan 27, 2022 1:46 pm That commit probably does -- that was the "emergency" part of the fix. The rest of the refactor took a little longer, but I pushed it last night, in git commit bfada57b0. That should eliminate the extra CPU usage.
Everything back to normal (at least apparently :P) with this commit. Thx.
PS : just saw I mistook on my previous post. Did not see that the pointed commit already was in the master. :oops:
TheMarkster
Post by TheMarkster »
user1234
Post by user1234 »
While starting, yes, but i edited the preferences, to load all modules at start. While running, no (not yet).
Anyway, it seems to be solved.
Greetings
user1234
