Path help needed (RT branch)
mnswamp
Post by mnswamp »
If this is the wrong place, please let me down gently :)
First, I'm a boomer. There, I admit it. Learning FreeCAD has been interesting, frustrating, rewarding, but sometimes I just want to tear out the few hairs I have left... This has been one of those struggles.
I am building a teardrop trailer, and want to CNC the walls (among other parts). The walls are 5ft x 10 ft overall, which is slightly larger than a single sheet of 4x8 plywood. After considerable scratching around, I figured out that I had to cad each of the 4 sections individually, which doesn't seem the most straightforward process. So I made the switch to RT's branch, which *does* allow sectional padding.
Everything was going OK. I _understand_ that I am not using the full potential of the branch. It will take me some time to digest the concepts for linking models - I learned to draft with a triangle and t-square. 3D parametric CAD is a mind altering experience.
But I thought I had it - created the job, moved the bits around to fit in the box, created a profile operation, and then went to simulate it and boom. Crash, no warning, no errors shown. Fortunately the next time thru, I saved everything, and have loaded it here: https://drive.google.com/file/d/1DWaOn8 ... sp=sharing
If someone smarter than me (and that won't take much) could be so kind as to take a look, I'll buy the virtual beer and be forever in gratitude. If I'm totally missing something fundamental, I'd love to know that too.
BTW, running tonight on Win10, FreeCAD-asm3-Daily-Win64-Py3-Qt5-20220111
Many thanks,
marsh
Organizational chaos monkey
President, Twin Cities Paddlesports
BoD, Twin Cities Maker
"Geek by profession, maker by prediliction, coach by avocation, sports-hack by obsession"
Re: Path help needed (RT branch)
That sounds like an issue with the branch. I move the topic to the Assembly forum, where the branch is discussed.
wsteffe
Post by wsteffe »
hello mnswamp.
I looked at the document uploaded by you but what is the problem ? You said it crashed but what do you did when it crashed ?
mnswamp
Post by mnswamp »
All it took for me to crash it was to attempt to run the GCode simulator. It took about 3 seconds and crashed.
mnswamp
Solved. Painfully, but solved
Post by mnswamp »
OK, 24 hours later, and I've solved at least a few of my issues.
1. Something in one of the sketches was terminally borked
2. My process was pretty bad
3. Starting from a clean sketch, and using external reference dimensions cut a 4 hour task to about 15minutes to break out the sketches.
4. Once I had the sketches broken out using external dimensions, I still had to copy each, minus the linkage to the master sketch, then pad each individually.
5. Then on to path and creating a job file. It took me a _number_ of attempts at #4 above to get manipulating the stock and models. TBH, this is one of the weirder process flows in FreeCAD. Actually, I spent a couple of weeks trying figure out how to do it in FC. RealThunder's efforts are amazing.
At the end of the day, I have been able to successfully generate gcode for two 5x10 trailer walls split into 3 4x8 sheets of plywood.
Thanks for anyone who perused my original ranting. I do love this tool, but sometimes there's a real desire to go learn vCarve or something else for working in panels.
