Lonfor wrote: ↑Tue Apr 26, 2022 1:27 am
Sorry for the off-topic and kinda hijacking the thread.
That happens, and i think i was the first hijacker.
Extreme complex or interlace skeleton can work, but only on a (few) circumstances. For example when only one person work on a complex skeleton, then of course, then for this one person it can work. But i you have exchange people, then it will be hard to figure out, what is linked in the skeleton and what not (even something is sketched in the skeleton, it must not be linked or can generally deviate). I know that in some companies, this way of work is forbidden.
Also it can work (with more people), when it is always 100% the same part/s / assembly/ies with 100% same topology and only different dimensions. But this is very seldom and maybe build up in an other way. Or when all parts always extreme homogeneous and a quasi internal norms.
Also it can work, when the build up is pretty obvious. For example your laminated springs, i would absolute agree, that is a good example to do this in a skeleton way. But also the pretty opposite is your example the frame. It makes changing things unnecessary hard and when elements linked to other attached parts, which maybe other people work on, the result can sometimes intersect. Also when skeleton attached to other parts, for example on sections, it could inveigle to people to think, it changes all correct automatic with it. Maybe it is true for the section, but maybe not to other things like: wall thickness, mounting access/possibility, fabrication/machining access/possibility, ...... . So when you know, it does not change automatic, at least you are nudged, to look at the other parts exactly. And when change elements in a complex skeleton way and it have impact on this points and you have to change things on it, it can happen, that you have to change also the skeleton itself (topological), which can have impact on also other parts which is also linked to the skeleton, which maybe do itself not change per se, but you have to relink/correct some elements.
So often, not always, a simple skeleton for assembly, movement, or (simple) section definition is more preferred, as a complex skeleton model, at least in the mechanical engineering. In the vehicle manufacturing (which i worked many years ago), this is maybe a little bit different, but at that time i worked on it, it was strictly forbidden (reason for dismissal).
Greetings
user1234
