Mentions extension
- adrianinsaval
Re: Mentions extension
hmm I'm getting frequent logouts but haven't noticed a connection to that, let's try it in this post @user1234
Edit: nope, I'm still in, I think I usually get kicked out when I use the forum on different devices without much time difference. Also, are you using freecad.org or freecadweb.org?
Thanks for testing!adrianinsaval wrote: ↑Thu May 26, 2022 10:27 pm hmm I'm getting frequent logouts but haven't noticed a connection to that, let's try it in this post
I also now use a mention and did not kicked out. But i get kicked out in this session before. I enter with freecad.org, but it linkes to freecadweb.org. Is this changed? Was not freecad.org changed to the new standard?
Greetings
user1234
edit: typo
- adrianinsaval
The stay-logged-in recognition is based on IP. If your provider changes it frequently, you may not be properly recognized. Solution: stay logged in 24/7 and help around the clock .adrianinsaval wrote: ↑Thu May 26, 2022 10:27 pm Edit: nope, I'm still in, I think I usually get kicked out when I use the forum on different devices without much time difference.
Now I'm certain that @chrisb is suffering from an often changing IP adress
Regards / Viele Grüße
Max
Max
I had a couple of network-related issues too these last weeks with the forum, disconnection, posts that timed out, etc. I think there must have been some hiccup somewhere... But it seems back to normal now
Feature request: can we give the mentions a slightly transparent background to help differentiate the font from the background itself. Here's an example of how I see mentions after they've been altered via the CSS
See below:
See below:
In your screenshot the background is the same as the rest, so it seems already to be transparent.
I guess I was asking to add some opacity to the background of the font so it differentiates better.
Maybe another color, simply?
The thing is, I'm hesitating to modify the plugin, because then it'll become complicated to update... Better to do this with theming I guess, once we decide to rewrite a good FreeCAD theme
