Crash after start
xadox
Re: Bug: Program received signal SIGSEGV, Segmentation fault.
Post by xadox »
wmayer wrote: Mon May 23, 2022 1:01 pm Add this to user.cfg:
But it doesn't help
Instead of
$ ./FreeCAD.exe
[7684:6160:0523/152047.325:ERROR:gl_surface_wgl.cc(388)] wglCreatePbufferARB not available.
[7684:6160:0523/152047.325:ERROR:gl_surface_qt.cpp(197)] Requested OpenGL implementation is not supported. Implementation: 1
Illegal storage access...
Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: Illegal storage access! Please save your work under a new file name and restart the application!
Segmentation fault
now i see
$ ./FreeCAD.exe
Segmentation fault
Founder
Post by wmayer »
Can you post again your crash.log, please?
xadox
Post by xadox »
wmayer wrote: Mon May 23, 2022 3:22 pm
yep
crash.log
(46 KiB) Downloaded 12 times
Founder
Re: Crash after start
Post by wmayer »
The callstack is pretty much the same as for the previous crash. So, it seems to be a general OpenGL problem with KVM and I don't know how to make it working.
You can try to remove/delete the directories Start and Web to avoid to load the WebEngine module. You may get starting FreeCAD but then very likely will see a crash as soon as you create a new document.
thomas-neemann
Post by thomas-neemann »
xadox wrote: Fri May 13, 2022 11:40 am ....Windows Server 2019 Standard Evaluation....
is windows server suitable for freecad?
xadox
Post by xadox »
thomas-neemann wrote: Mon May 23, 2022 7:05 pm
Why it cannot be?
thomas-neemann
xadox wrote: Tue May 24, 2022 9:42 am ...
I don't know, but for games it's e.g. probably unsuitable
https://www.reddit.com/r/windows/commen ... just_dont/
xadox
Post by xadox »
wmayer wrote: Mon May 23, 2022 5:03 pm You can try to remove/delete the directories Start and Web to avoid to load the WebEngine module. You may get starting FreeCAD but then very likely will see a crash as soon as you create a new document.
I tried but i had the same error.
Founder
Post by wmayer »
What does the crash.log say? The callstack should be quite different now.
Post by Kunda1 »
wmayer, does it make a difference that v0.19.x is being used and not v0.20dev?
