Feature request: Let ValidateSketch detect double lines
We know from many posts that there were troublesome newbie sketches with elements of zero length (by bad clicks) or double lines. While zero length is meanwhile caught by the sketcher it can still happen that e.g. two lines lie on top of each other, and all ends are connected, so that Sketcher ValidateSketch will not complain. Such sketches cannot be padded.
I propose that ValidateSketch checks for coincidences where three or more edges of real geometry (i.e. no construction geometry) coincide.
For one of the many topics where this is discussed, see https://forum.freecadweb.org/viewtopic. ... 91#p595891.
Shalmeneser
Re: Feature request: Let ValidateSketch detect double lines
Post by Shalmeneser »
+1
Something like Highlight troublesome vertexes ?
Polyline tool sometimes create null lines when playing with 'M' key.
Is it sensible to have a single button checking for "Paddability", i.e. no open vertices, no T, no X, no double elements?
Bance
Post by Bance »
I like this.....
Could wrong direction be added as well? (As in padding will create two solids.)
Bance wrote: Fri May 20, 2022 7:52 am Could wrong direction be added as well? (As in padding will create two solids.)
I see that rather not as a property of a sketch, but rather as a property of the follow-up feature, although they are of course related.
For such things it could be helpful to have an augmented sanity check.
Bance
Post by Bance »
If padding would lead to a non continuous solid,is that not padability?
Edit
I mis-read your initial reply, I see that you basically agree, apologies. :D
adrianinsaval
Post by adrianinsaval »
Bance wrote: Fri May 20, 2022 8:37 am If padding would lead to a non continuous solid,is that not padability?
Edit
that essentially requires performing a pad and checking if there are multiple solids, but then what length should be used for the pad? Remember that PD now supports multiple levels of nested profiles as long as the end result is a single solid (logically if it is the first feature in the body it will fail).
Bance
Post by Bance »
I would have thought it just required checking the placement and the normal direction....
And if its too complicated Meh!
thomas-neemann
Post by thomas-neemann »
I believe that programs that try to catch user errors become unnecessarily slow and error-prone. I think there are more important things, e.g. mirroring of sketches with constraints and reverse processing
thomas-neemann wrote: Fri May 20, 2022 5:02 pm I believe that programs that try to catch user errors become unnecessarily slow and error-prone.
We are not talking here about the normal workflow, but rather about a dedicated tool checking for common flaws in sketches. Such a tool woul dmake the program slightly bigger, and thus would use more ram, but as long as the program doesn't start swapping, it should not at all affect normal workflows.
Bance wrote: Fri May 20, 2022 4:24 pm I would have thought it just required checking the placement and the normal direction
It needs a bit more, with an appropriate solid beneath the sketch you can pad it in both directions.
